Old 60's Porsche Tech
After engine overhaul miles before oil change valve adjust
Top end overhaul on 3.2 how many miles before first oil change and valve adjust, thanks
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Just the heads? Or new rings, etc.? Think 1st valve adjust is ~ 1100 miles.
Todd
'81 SC |
New rings also
Mine was run on the dyno, so I didn't do the first interval which I think is 100 miles. I did a 500 mile change. I'm also changing mine while I do my after break-in valve adjust, but that is mostly because it's taken me a year to drive ~ 1100 miles. All things being relative, oil is cheap (even the good stuff).
Todd
'81 SC |
Member 911 Anonymous
I would crack her open to make sure all is fine way before that. Heck, it is only little oil loss and valve cover gaskets, if that.
Then 1000-1100 miles later do the valve adjust, check torque of rocker shafts and oil change. Do a partial drop and remove cat/bypass if you want easier access. ( I personally hate adjusting valves with engine in the car but a partial drop is easier, removal is of course better )
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-09-2016 at 07:59 AM.. Reason: added shafts and oil change |
