rkeele's Avatar
cross post- 964 rod length question
I have run into both Carrillo and Pauter rods that are about 2mm longer for 964 does anyone know why these are made for 964? thanks Bob
Old 07-04-2016, 09:24 PM
prschmn's Avatar
Long rods
They are used with pistons with a reduced compression height-less rod angle
means higher RPM capability-and makes better power due to increased dwell time.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 07-05-2016, 05:37 AM
rkeele's Avatar
Interesting Mark , so not recommended for use with Factory 3.8 rsr pistons? even if they are the 11.3 ones? wouldn't you need to shim the cyl. base also? thanks Bob
Old 07-05-2016, 10:35 AM
prschmn's Avatar
No. RSR pistons are built for a specific rod.
Mark
Old 07-05-2016, 02:09 PM
