Schleprock
Speaking to the Webers themselves, as long as you're planning to do work on them anyway, make sure the accelerator pump covers and the pump body (the block of metal) are flat so they will seal properly. The accelerator pump area is notorious for weeping or dripping.
You can flatten them yourself very easily with some fine grit wet sanding paper on a flat piece of glass. Color the surfaces with a permanent marker and you can watch your progress as the color is sanded off the uneven surface.
Kevin L '86 Carrera "Larry" |
. It was very clear. 👍👍
K-Jetronic student
Very helpful. 👍👍👍
K-Jetronic student
Just one more question to have it all clear:
What is the maximum recommended overbore on a standard 2.0 L cylinder? How far can we go, considering the safe minimums...?
K-Jetronic student
Overbore
Alex,
First you have to find an overbore piston that will fit in that cylinder and work with the 2.0L heads. Every bit of metal you take away from a stock cylinder reduces the cooling capacity of that cylinder, which isn't a good thing. I don't have any experience with boring stock cylinders, so I will leave it to others to chime in. For me, I think the 82.5 set form AA with JE pistons is your best bet. You can sell the set you have and be out about $900. If you decide to go with the 2.2 heads, you will probably be out over $2,500, depending on availability in your area . I paid about $2,200 three years ago for some 2.2S heads that were fully rebuilt with sodium cooled exhaust valves and the larger 36/35 S ports to put on my 2.0 MFI engine with 2.2L S pistons. I originally built this engine in the early 80's with 2.0 heads (modified for the head gasket) and 2.2S pistons. Nobody told me at the time that I would be way down on compression. I never started that engine. Tore it down at the beginning of the year to put the 2.2 heads on it. I did tell you that I had "been there, done that" didn't I. Bob B |
Many Thanks Bob!
Now all is clear and I have the right information to take the best decision. 👍👍👍👍 Thanks to all who posted usefull information!
K-Jetronic student
Under the radar
