Try not, Do or Do not
Henry Schmidt's Avatar
68 soft window gets a new heart
Recently completed project
2.8 70.4 X 92 PERFORMANCE ENGINE
CUSTOM BUILT TO 2.8 PERFORMANCE STREET SPECIFICATIONS
REBUILT 46mm WEBERS
68 ALUMINUM CASE (install piston squirters)
OIL BY-PASS MODIFICATION
92 MM JE PISTONS 9.5:1 COMPRESSION (skirt & dome coating)
MAHLE CYLINDERS
2.4 CRANK (cross drilled, magged and polished) 70.4 stroke
SUPERTEC HEAD STUDS
GROOVED & COATED MAIN BEARINGS
COATED CLEVITE ROD BEARINGS
COATED INTERMEDIATE SHAFT BEARINGS
UPGRADE OIL PUMP (venturi strainer) AND PUMP MODIFICATION
NEW TIMING CHAINS, RAMPS & SPROCKETS
TURBO CHAIN TENSIONERS
SUPERTEC TENSIONER ARMS
CARRILLO CONNECTING RODS
COMPLETE ENGINE BALANCE .5 GR.
DOUGHERTY RACING BILLET CAMS (DC40)
SUPERTEC SYSTEM RECONDITION ROCKERS AND SHAFTS
EIBACH RACING VALVE SPRINGS & SUPERTEC TI RETAINERS
COMPLETE VALVE JOB W MAGANESE / BRONZE GUIDES
OVERSIZED (47mm X 41mm) VALVES
2.4 LITER PORTED (40/38) & SURFACED HEADS
BURNHAM PERFORMANCE (BP) TWIN PLUG DISTRIBUTER
CUSTOM PLUG WIRES, BOSCH PLUGS, BP CAP AND ROTOR
SUPERTEC PLUG CONNECTOR HOLDERS
SUPERTEC PLUG WIRE HOLDERS
BP OIL SUMP COVER
GOLD CAD COATING ON HARDWARE
2.0 FLYWHEEL (resurfaced)
REBUILT ALTERNATOR & CUSTOM HARNESS
CUSTOM FACTORY AIR FILTERS
SACHS CLUTCH PACKAGE
SSI HEATER BOXES
M&K MUFFLER
SERIES 900 AMBER FAN SHROUD & SHEET METAL
Completed engine
How it got there
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-08-2016, 01:20 PM
Henry Schmidt
Ph: 760-728-3062
Old 10-08-2016, 01:26 PM
Henry Schmidt
Ph: 760-728-3062
Old 10-08-2016, 01:34 PM
Henry Schmidt
Ph: 760-728-3062
Old 10-08-2016, 01:43 PM
Henry Schmidt
Ph: 760-728-3062
Old 10-08-2016, 02:23 PM
READY TO SHIP
Henry Schmidt
Ph: 760-728-3062
Old 10-08-2016, 02:30 PM
UnRegistered User
billybek's Avatar
Beautiful!
Whose studs did you use?
Break in on the dyno? What numbers are you expecting?
Bill K.
Old 10-08-2016, 03:24 PM
Cairo94507's Avatar
Just a work of art and perfection. That owner is a lucky person to receive one of your engines.
'71 914-6 #0372
'17 Macan GTS
Old 10-09-2016, 06:15 AM
Plays with cars's Avatar
Damn Henry! You need to put a warning at the beginning of posts like this. I had kids in the room with me and they almost saw the pictures of this raw sexiness that you posted.
Mark B
'73 911S (long term ownership) '70 914-6 (long term project) '74 914-2.0 (sold)
Old 10-09-2016, 08:39 PM
gestalt1's Avatar
Great attention to detail! Thanks for posting the pics!
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 10-10-2016, 04:48 PM
Looks like a good solid day or two of assembly there!!
Curious, what magic goo did you put on oil return tube o-rings and also the o ring behind the camshaft retaining plate?
Old 10-11-2016, 07:38 PM
The "magic goo" is Dow 55 o-ring lubricant. Experience shows us that Dow 55 is a exceptional product for building these engines because it lubricates the o-ring for ease of assembly and as the engine heats up, the chemical properties of this Mill spec lubricant causes the seal to swell slightly to increase surface contact and increase "crush resistance".
Thank you all for the kind words.
As much as I enjoy sharing our process, the real purpose of the post was to show the readers that we use the exact techniques that I advocate on this forum.
Some people have suggested that I post here simply to sell our parts and as much as I appreciate the sales, helping Pelicans build the best engine you can is actually our goal.
Henry Schmidt
Ph: 760-728-3062
Old 10-13-2016, 06:31 AM
al lkosmal's Avatar
Nice Henry......really nice.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 10-13-2016, 08:59 AM
beautiful. Why the yellow fan shroud? Hot rod? Pix of the car too please!!
Old 10-13-2016, 10:13 AM
The fan shroud is a replica of the factory Amber racing shroud. Sometimes the computer distorts the tint.
We don't work on the cars so we rarely have pictures of the finished project.
If this customer chooses to send me a picture, I'll post it with his permission.
Henry Schmidt
Ph: 760-728-3062
Old 10-13-2016, 11:25 AM
Wow, is all I can say.
Lorne M.
83 SC
Old 10-16-2016, 10:48 AM
304065's Avatar
I like the jet nuts you are using on the carb flanges. What are they 12mm across the flats?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-20-2016, 08:31 AM
The Jet nut on the intake manifold is a 8x1.25 with a 10mm head. It's one of the few nuts that fit the PMO manifold.
The nut we like for mounting the carburetor is a tall 8x1.25 with an 11mm head. The tall nut makes for easy access.
We have a kit that includes 12 Jet nuts, 12 tall nuts and 12 an washers.
Henry Schmidt
Ph: 760-728-3062
Old 10-20-2016, 10:59 AM
Under the radar
Trackrash's Avatar
Awesome. Thanks for sharing.
I especially like the stainless braided cam oil lines.
Why the single air filter? Won't that affect the HP?
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-20-2016, 03:47 PM
