it's me ahahaa
Olies is a good call. Probably want the oil bypass mod and Case Savers instaled while you are at it.
Chris |
Before anything is done the bore diameter should be measured. Often you'll find that it has actually become smaller and if that's the case it can be line honed-not bored into spec without having to surface the case halves. You do need to put an alignment plug in the intermediate shaft bore
to get a good result though. Most of the rigidity is in the mainline and a few out on the perimeter isn't a big deal. I do usually install locating sleeves towards the center as a precaution.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
case
Good advice from Mark.If the straight edge is flat on the case halves sometimes all you need is a clean up line hone.Fred
Send the case to Olies. Excellent work and fair price. End of story. R/Dave
| Tags |
| crankcase , machine shop , mag , wrap |
