TPS Sensor
Trying to track down my intermittent accell problem. Engine idles good,starts good. Fuel mixture good. But from time to time, accelerating from a low rpm, it will just not rev up like the engine does not know the throttle is opening. Could their be a bad spot on the TPS sensor?
3.3 ltr, stock compression, efi, twin turbo - no intercooler. |
Chain fence eating turbo
What car? Vacuum leaks will exhibit this running condition.
Schleprock
Are we talking about a 3.2 Motronic/Carrera engine? Could be the TPS which you can check for function with a multimeter for it's resistance values throughout the travel range.
Also could be a faulty airflow meter. The airflow meter has a wiper arm that pivots and tracks on electrical contacts inside the unit. Over time that contact gets worn and can create a driveability issue.
Kevin L '86 Carrera "Larry" |
the tps is only a switch on a carrera. turns off the AC when at full throttle. Your AFM is likely not working. this would be a good time to make the MAF mod and get some more horsepower.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
