Is this a stupid way to hold my crank for building?
I held my flywheel up to my engine yoke and two holes lines up perfect. So I ran up the hardware store and got a couple longer bolts, plus a couple spacers to mount it up. Feels solid. The flywheel isn't bottomed flat on the face of the yoke (it's maybe .5mm away) so there is a tiny bit of flex. I don't want to damage my flywheel though. Think this is a stupid way of doing it?
That crank is heavy. I'm not sure the flywheel was intended to have to support it when bolted in at the edge.
When I did mine, I threaded a few of the old crank-to-flywheel bolts in and the set the flywheel on a table. My approximate order of operations was: - Install mains in case. - Install crank in case do Plastigauge fit-up (before rods were on crank). - Take crank out of case. - Put crank on flywheel, but flywheel on table (crank goes vertical). - Clamp flywheel to table to prevent toppling. - Install rod bearings and rods. Hope this helps. |
Thanks for the sequence. Sounds like you Plastigauge the mains, but not the rods? I've never heard of that before. It's the opposite in Wayne's book. Am I missing something?
I decided the spacers were not helping my setup. So I removed them and cinched the flywheel down so it's now resting flatly against the yoke. I also rotated the whole setup so the weight of the crank is into the yoke instead of away from it. It's solid as a rock. ![]()
Member 911 Anonymous
Oi, try placing it on the flywheel as a support.
to install the rods for plastigauge work. Maybe on the cleaned floor for leverage.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Sorry - I omitted the plastigauge step on the rods. (I checked clearance on both the rods and the mains with plastigauge.)
It may feel solid, but I still recommend setting that crank vertical (flywheel horizontal on a table). |
or at least support the pulley end somehow.
Perpetual Reassembler
I believe there is a factory tool that holds the crank in the horizontal position but I do not have one. I had a junk engine adapter that came with my stand (probably for V8 engines?) and I drilled the crank/flywheel hole pattern into it to bolt the crank on.
As you can see I drilled one hole incorrectly. So far so good. ![]() ![]() ![]() ![]() I did try to center the holes around the axis of the tube but the tube diameter lands right on the crank/flywheel bolt circle and didnt work. This is why they are offset on the adapter.
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer |
Why not make some V blocks out of some wood or something....
Personally, I would never hang my crank from one end like that without support. Dump the plasti-gage and buy the tools or pay a machine shop a few bucks to measure and match the bearing to the bores to the journals. |
Chain fence eating turbo
I wouldn't do it, and I'm not the overly cautious type sometimes.
![]() That is a lot of moment weight on there once you start adding bits. |
i always just bolt the flywheel on and set it on the bench standing up. which is how cranks are supposed to be stored when not bolted into a block
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
For reference, here's the factory tool for doing this job, goes into the P313 bench mount clamp just like the yoke can.
![]() I made my own from some good angle steel and just clamp it in a regular bench vise. andy |
Well, I've been paranoid about warping my flywheel after posting this. So I had my steel shop burn out a "bow tie" which I used as an adapter between the crank and the yoke. Works great. And now my flywheel is resting easy on a shelf.
I'm surprised no one makes something like this. Or maybe they do... ![]() ![]()
I wouldn't worry about warping the FW as much as the crank
Wait, what? Warping the crank? Factory has a tool specifically for holding the crank horizontal, Wayne mentions it in his book, countless builders do this. I'm pretty green here, so what am I missing?
I would rather be driving
I use a junk flywheel and clamp it in a vise. Makes it really easy to assemble and torque the rods. Go for it.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I wouldn't store it that way. That's me. The tolerance for the crank journals are measured in ten-thousandths. Bet you could put a dial indicator on the end of the crank opposite the flange and flex it slightly. |
Schleprock
Stomski makes a very nice one that supports the crank at both ends, in either vertical or horizontal position.
https://www.stomskiracing.com/products/911-crankshaft-holder
Kevin L '86 Carrera "Larry" |
I'm not going to say if it's right wrong ok or not. It's your crank you do what you want.
But from my experience with machine tools. Specifically with leveling a lathe and taking the twist out of a heavy cast iron lathe bed. You suddenly become aware how "plastic" cast iron and steel really is. It's a real eye opener. With that being said. I guarantee you that crank is bending in your fixtures under its own weight. |
You seem "bent" on mounting this in a cantilevered position. I worry that the jig you fabricated means the crank will sit that way for a period of time, allowing gravity to possibly have an effect on the straightness. As no carrier suggests, set it on a pair of v-blocks or equivalent or mount the flywheeel, then set it vertically on the workbench. A large lazy susan below it will allow full access to measure and inspect. FWIW, when work space was at a premium, I rebuilt an entire engine with it sitting on a lazy susan. However, your crank, but you asked.
