Hewh good news. I think you are fine just make sure you go back to insure all studs did not come loose.
Yes, it is stock 3.2 pump. No I did not send out the pump but did have the IMS sprocket inspected. I simply cleaned it and checked for slop. Zero Slop but I did replace the hold down bracket/washers and of course the IMS bearings. |
Running Super Clean :-)
FINAL Update:
Smogged: PASSED with Flying Colors :-) Seriously, she never ran so clean. One of the reasons I stuck to 3.4L build. Cat On Stock 3.2 Chip Brown Cali Wire Adjust AFR back to 14.7:1 from 14.3:1 Idle set to 800 Half Tank of Gas 200F Engine Temp on DELO LE 15W40 Tire Pressure at 32LBs but probably 34-36 after the drive there http://forums.pelicanparts.com/uploa...1534980802.jpg |
| All times are GMT -8. The time now is 04:10 PM. |
