-   -   Part Trois: 3.4L Build, The Journey (http://forums.pelicanparts.com/911-engine-rebuilding-forum/948857-part-trois-3-4l-build-journey.html)
DRACO A5OG 03-09-2017 11:46 AM
Day 1:
All parts are in! :cool:
Crank Shaft:
  • Crank Shaft, Polished, Verified Straight, No Cracks, Oil Pathways Clean and Snout Fixed
  • Rods, Resized (STD), Straightened, Honed and New Wrist Pin Bushings
  • Bolt/Nut kit, ARP M9 Bolt/Nut Kit 40ft lbs
  • Clevite 77 (STD) Bearings, measured (Tab) 1.476MM, (Center) 1.495MM (Non-Tabbed side) 1.476MM, Consistent on all bearings, thicker in the middle as it should be
http://forums.pelicanparts.com/uploa...1489088459.JPG
http://forums.pelicanparts.com/uploa...1489088495.JPG
Notes: ARP M9 Nuts require a 12 point ( Triple Square ) 11MM Socket
Bought this toy to verify my torque settings, works very well considering it is from HF
http://img.photobucket.com/albums/v5...pspx1yzevm.jpg
DRACO A5OG 03-09-2017 11:47 AM
Case Assembly:
Last measuring task:
Ground ( well, I chickened out and had a Pro do it at Vellios $45, Yes I cheated ) and Measured Ring END GAP
http://img.photobucket.com/albums/v5...ps5gllfkkx.jpg
Top .017
2nd .022
Oil Retainers .015
Don't worry fellas, the file is for any burrs the shop missed, they didn't :D
DAY 2:
Oil Pump/IMS with New Bearings & Chains, installed
GT3 STD Bearings, installed
http://forums.pelicanparts.com/uploa...1489207386.JPG
DAY 3-4:
Chamfered, D-side Case thru holes and two behind the Oil Cooler (side tracked, modification needed)
http://forums.pelicanparts.com/uploa...1489372472.JPG
Case Sealed, used Master Henry Schmidt's method of Case Thru tighten without O-rings as not to panic on time but I still needed to tighten the perimeter nuts within the time limit. She is sleeping over night, O-ring with Dow55 Tomorrow.
Used Brand New M8 Oval Lock Nut and M8 Crush Washer for the perimeter.
Test Turned the Crank, All Rods moved freely and drop on their own weight, Wow, Smooth :D
http://forums.pelicanparts.com/uploa...1489471047.JPG
ARP Head Studs, installed :D
http://forums.pelicanparts.com/uploads26/IMG_4599_1_1489562389.JPG
Tested Rotation, SUCCESS!
<iframe width="640" height="360" src="https://www.youtube.com/embed/4brUhjCIFw4?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
Cylinder, Rings, Piston, Head and Cam Tower Assembly
Had to wait a week for my WISECO RCS09800 true 98MM Ring Compressor Sleeve/Installer, HIGHLY RECOMMENDED!
https://cdn.shopify.com/s/files/1/02...g?v=1437618113
Day 5
Measured Deck Height, glad EBS spec'd for 3.2 heads so I still have the step, it allowed me to measure deck height easily.
http://forums.pelicanparts.com/uploa...1490234483.JPG
Don't mind the gauge, I dropped it and then stepped on it, also take pic cock eyed the readings
Measured 6 times :D, OCD like that
Heads torqued down verified flat as the Salt Flats.
http://forums.pelicanparts.com/uploa...1490287481.JPG
Next, Cam Tower, Camshaft, #1 & #4 Rocker prep for Timing :D
Another tool recommended either the Stomski Wrist Pin install tool or Porsche 964 Wrist Pin installer, you have to mod the side tabs but it works freakin great.
http://forums.pelicanparts.com/uploa...1098899373.jpg
http://forums.pelicanparts.com/uploa...1098899496.jpg
DRACO A5OG 03-09-2017 11:48 AM
Day 6-7
Timing Set, A successful 1.25MM both sides:
http://forums.pelicanparts.com/uploa...1490811185.JPG
She is smiling at me :D
Proper Tools really is a Must! Thanks again Master KTL!
Weekend Break:
Did some Bling, used Craft's Store Metal Oil Based Paint Pen to paint the Logos on the intake and upper Valve Covers, came out pretty nice :D
http://forums.pelicanparts.com/uploa...1491098765.JPG
Hot bathed in DishWasher :-P
http://forums.pelicanparts.com/uploa...1491477969.JPG
ASSEMBLY COMPLETE DAY 12-14 ( Actual time 4 months waiting for parts and machine service but working on her, about 2 weeks )
http://forums.pelicanparts.com/uploa...1491558309.JPG
Glad to report, no extra bolts and or nuts. WOO HOO :D
Next, install and break in, Joy Joy Joy
DRACO A5OG 03-09-2017 11:49 AM
The Break In:
Step 1: Filled with 30 weight SAE Rotella
Step 2: Hand Cranked to insure nothing is binding, Nothing is Binding :D
Step 3: Cranked with Starter, DME disconnected NO FUEL, Cranked Smoothly and Effortlessly
<iframe width="480" height="270" src="https://www.youtube.com/embed/fSEWwCUuawM" frameborder="0" allowfullscreen></iframe>
Step 4: Start, Run at 2000 RPMS for 20 Minutes, check for leaks, DUMP OIL, Change Filter.
<iframe width="640" height="360" src="https://www.youtube.com/embed/0l_gX9y81es?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
<iframe width="640" height="360" src="https://www.youtube.com/embed/uLOeDxIVP9s?feature=player_editpage" frameborder="0" allowfullscreen></iframe>
<iframe width="640" height="360" src="https://www.youtube.com/embed/xmO7qwaVP6w?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
Step 5: Refill with 30 Weight, Drive Her for 50 Miles, All RPM ranges and decels, check for leaks, Dump Oil, Change Filter.
Step 6: GO visit Mom in Fresno 600 mile round trip, check for leaks, dump oil, change filter, Put in DELO 400 15W40.
kyngfish 03-09-2017 11:58 AM
Lol
For a second I thought, why does your CS have eyelashes?
DRACO A5OG 03-09-2017 12:03 PM
http://forums.pelicanparts.com/suppo...s/smileJap.gif
KTL 03-09-2017 12:37 PM
Sweet.............
Tippy 03-09-2017 12:58 PM
I would really consider a bolt-stretch gauge for the rodbolts.
Mine were all over the place final torque wise.
Beg, borrow, or steal one.
Our rod bolts are the weak link being smaller IMO.
DRACO A5OG 03-09-2017 01:01 PM
Yeap
Will redo with gauge Master KTL lent me :cool:
Tippy 03-09-2017 01:03 PM
That's great to hear!
cgarr 03-09-2017 05:09 PM
I like the flooring. Just had ours done.
DRACO A5OG 03-09-2017 06:12 PM
Verified:
0.0105"
http://forums.pelicanparts.com/uploa...1489111898.JPG
Surprising, for a POS HF unit, but it wasn't typically cheaply priced :eek:
Tippy 03-09-2017 06:54 PM
You're stretching 10-thou? Forgot it was that much!
DRACO A5OG 03-09-2017 06:59 PM
Yes sir, ARP spec states .0100-.0105" or 40 ft lbs
Trackrash 03-10-2017 12:23 PM
Originally Posted by DRACO A5OG (Post 9504523)
Reserved for Cylinder, Head and Cam Tower Assembly
Have you figured a way to post a pic when editing?
DRACO A5OG 03-10-2017 12:46 PM
Yeah, Wayne forgot to add that feature on editing. So I just copy from photo bucket and paste :eek:
KTL 03-10-2017 01:29 PM
Gordon & Jim,
I do it this way. Create a new reply, use the picture upload feature and the link/path for the picture is created. Copy those picture path(s) and paste it into the placeholder post you want to edit. Easy way to do this is have two Pelican windows/tabs open at the same time on your 'puter- one for the new reply (doesn't even have to be the actual thread we're on) and one for the editing of the placeholder post. The key is, DO NOT click on the submit button for that new reply which you created for nothing more than uploading pictures.
Make sense?
DRACO A5OG 03-10-2017 01:34 PM
Lol
Never give up Never surrender :cool:
KTL 03-10-2017 01:49 PM
No commercials, NO MERCY!!!!
https://youtu.be/ipsPgNEmAXI?t=2m28s
