Show me your valve spring compressor
Looking for valve spring compressor's that work well on the 911. What is everyone using?
Old 04-02-2017, 07:17 AM
Heads on or Heads off?
Old 04-02-2017, 08:14 AM
Chain fence eating turbo
911 springs are very weak stock form. Those cheap, C clamp styles ones with the adjustable jaws should be fine.
Old 04-02-2017, 08:36 AM
I have a C clamp type you use with the head off the motor that I got at Sears. It works OK with stock valve springs but it's a little flimsy so after market high performance valve springs are probably too much for it.
You get what you pay for and ebay would be a good place to look for a high quality used one.
Old 04-02-2017, 01:27 PM
abit off center
cgarr's Avatar
______________________
Craig
G2Performance
Old 04-02-2017, 02:59 PM
I bought a C-clamp yesterday to do that. Thanks for the pix
Old 04-02-2017, 06:38 PM
Jon B.
Vista, CA
Old 04-02-2017, 11:53 PM
P7E & P7I valve spring compressors.....
These are P7E and P7I valve spring compressors used by shop or race mechanics to quickly inspect and test valve springs or bent valve/s for assembled motor.
Tony
Old 04-07-2017, 07:02 PM
Originally Posted by boyt911sc View Post
These are P7E and P7I valve spring compressors...
Those are available from Pelican, order numbers PEL-TOL-P7E and PEL-TOL-P71.
They're designed to attach to the cam towers.
Jon B.
Vista, CA
Old 04-07-2017, 11:18 PM
