Tks Steve
The galley plugs are the press in plugs that look like freeze plugs?
Do you purchase those locally?
Tks for your responses
ed
Old 07-27-2017, 06:05 AM
Ed - I have a lathe so I make the plugs from alu round stock. I guess steel core plugs would work if they are the right size, do a search on here to see what people use.
Old 07-27-2017, 06:26 AM
Originally Posted by outsider347 View Post
Tks Steve
ed
You can buy them from our host
Old 07-27-2017, 06:28 AM
Another thing I like to do, use extra long exhaust studs and machine stainless spacers for under the nuts. This does two things, it makes the nuts easier to get to (Ronnie, your response goes here) and if you ever want to remove them and one doesn't want to come off you can cut it off and still have enough stud left for a new nut. I use the copper plated prevailing torque nuts and never seize.
Old 07-27-2017, 07:20 AM
I have a lathe as well...do you happen to have the diemensions
Old 07-27-2017, 08:42 AM
I just measured the ones I knocked out and added a couple thou, don't know exact dimension. Once in I roughed up the plug and case and applied epoxy. There is one you have to pay attention to the depth, too deep and it blocks an oil drilling, forgot which one though, it's on here somewhere.
Old 07-27-2017, 10:35 AM
