-   -   3D model/render work on the 2.2T motor I'm building (http://forums.pelicanparts.com/911-engine-rebuilding-forum/971257-3d-model-render-work-2-2t-motor-im-building.html)
rwest 03-13-2018 06:05 PM
Your rendering work is amazing. I particularly like the exploded rocker arm picture- beauty in simplicity.
porschyard 03-17-2018 06:54 PM
Truly magnificent art
All i can say is wow, while your canvas and brush are a computer screen and micrometers you truly are an artist
boyt911sc 03-17-2018 09:13 PM
Michelangelo reborn........
Glen,
I get goose bumps looking at your computer generated images. You are a genius in my book. Please continue making more of your master pieces. Thanks for sharing.
Tony
hcoles 03-18-2018 07:20 AM
In a previous life I used UG, later named NX. Your modeling is beyond impressive. As mentioned people probably would buy posters/etc.
LIRS6 03-18-2018 03:55 PM
Fantastic work - thanks for sharing!
Jason
Optimusglen 03-22-2018 09:46 AM
thanks guys! I've started trying out some animation within the rendering software I use. Just teaching myself so it's all very basic, but thought you guys might enjoy it.
http://i.imgur.com/R4sGwu8.gif
mr-72 03-22-2018 01:11 PM
What rendering package do you use? vray, keyshot?
Optimusglen 03-23-2018 06:39 AM
Answered in the first post, Keyshot.
todd230 03-28-2018 12:32 PM
Originally Posted by 911T70 (Post 9936675)
Again, beautiful work! At first I thought I was looking at my car (post #98) but my daughter tells me the colour is not slate grey, but some sort of green (I'm colour-blind).! What colour is it?
After seeing your renderings, I realized that the oil-cooler duct was originally grey. On mine, it's black with a lot of scratches, showing the grey underneath, and it looked terrible. I stripped it and polished it and it looks great!
My car is very close to this color - VW Sea Blue
Optimusglen 03-30-2018 11:46 AM
Some more parts added.
http://c1.staticflickr.com/1/799/402...657c8da7_b.jpg
911T70 03-31-2018 04:49 AM
Gorgeous! Looking at it, I felt something was wrong and thought - 'OMG, he's made a mistake with the exhaust!'. I then remembered this engine goes into a 914, not a 911!
Optimusglen 03-31-2018 12:49 PM
Haha, yeah. I modeled the 914 exhaust first because I had a real set to build from. I do plan on doing a 911 orientation but for that I'll need to work off photos I find online.
Optimusglen 04-05-2018 11:19 AM
So it's looking like the case for my real 911/07 needs to be sent to Ollies, bummer but I suppose it was to be expected.
I've made a few additions to the 3D model, still so many details I need to tackle, and I haven't even started the throttle linkages.
http://c1.staticflickr.com/1/882/403...1583a4c4_b.jpg
If anyone is interested in an art print, I do have a few views up at society6.com/autoillustrated
Eric at Pelican Parts 04-05-2018 06:18 PM
Fantastic!! You never disappoint with these updates!
The animation with the rendering software is really cool. Do you have plans to animate the motor so it runs?
Optimusglen 04-10-2018 10:20 AM
Layouts for the heads
http://c1.staticflickr.com/1/792/404...8d914afb_b.jpg
http://c1.staticflickr.com/1/798/404...78131174_b.jpg
Optimusglen 04-16-2018 06:23 PM
http://c1.staticflickr.com/1/810/414...bb0dcc77_b.jpg
911T70 04-17-2018 04:10 AM
So cool! A beautiful thing of beauty!
Tippy 04-17-2018 05:24 AM
Can I ask how big the file is now in data and what kind of hardware are you running to be able make such a monster assembly?
My laptop fully spec'd from HP can barely run fixtures I've put together and sometimes takes hours to convert files from customers.
Optimusglen 04-17-2018 06:47 AM
I have a bit of a hotrod laptop. What video card are you running and how much RAM?
After I create the models I export as step files. A step file is a universal true geometry format that can generally be opened by any model software, but it's a "dumb" model in that if I want to change a hole size from 10mm to 11mm for instance, I can't just click on that feature and change the value from 10 to 11 like I could in the native file. The bright side is that the step file is a bit more compressed than the native file, the engine/trans assembly is about 200mb.
When I import the step file into my rendering software, the import process converts the smooth round surfaces into triangles, this is called tesselation. I choose how much tesselation on import, the highest value of 1 breaks the surfaces into billions of triangles and thus extremely large files. For my latest image that one was brought in with a tesselation value of 0.15 and contains 30,500,000ish triangles with a file size of about 650mb which is manageable. Here's a shot of a valve cover showing the individual triangles.
http://c1.staticflickr.com/1/887/408...6644d024_b.jpg
The software does this because it needs to calculate exactly how much light is reflecting where to make true photo-realistic images. Higher tessellation values make for more accurate reflections because it's breaking the surfaces up into smaller facets and calculating each and every one for color and light.
I have some files that are multiple gb, but much of that is because I brought everything in with a much higher tessellation value earlier on in my history.
And applying labels and decals brings the file size up a lot too. This Martini 914 model with my engine model installed is 5.5 gigs. If I brought this up and updated the tessellation value I could likely bring this down quite a bit though.
http://c1.staticflickr.com/1/895/392...992bcb2c_b.jpg
http://c1.staticflickr.com/1/879/401...e5a93776_b.jpg
Optimusglen 05-13-2018 04:55 AM
Throttle linkage done finally.
http://c1.staticflickr.com/1/904/413...4d248dc7_b.jpg
