Originally Posted by piggdekk View Post
Hi Catorce,
what's the difference in Your design that requires an orifice larger than the equivalent OEM part? The concept looks pretty straightforward to me.
thanks
luca
The flow characteristics are different because I have to maintain the same barrel OD as the factory, but the barrel INSIDE DIAMETER on mine is different because I'm using steel and I have to accommodate the threads for the cap. In my testing, if I used the same orifice as stock, my flow was slightly less. Bumping the orifice size up made the flow the same.
Old 12-21-2017, 09:08 AM
Originally Posted by tocobill View Post
Catorce
My understanding is the 993 turbo squirters were different then the others by flowing more via a larger orifice. How do your squirters flow compaired to the turbo versions? When will these be available for purchase?
I think you have a great product. Just about every other engine I have worked on had removable squirters that you can get into and clean if needed. It always bothered me about the 911 squirters and how flakey the testing can be when doing a rebuild.
So the only squirters I was never able to get my hands on were 993 turbo squirters, so the answer is I don't know. I think by varying the orifice size on mine, you could get the same flow. I could easily make a 3.0mm orifice that would outflow anything Porsche makes.
Oh, AVAILABLE NOW! I have 20 sets, already sold a set.
Old 12-21-2017, 09:10 AM
Originally Posted by al lkosmal View Post
Very cool. When will they be available?
regards,
al
Available RIGHT NOW! I have 19 sets left, 9 oversize and 10 standard. I can make more anytime, the machine shop is ready to produce another 20 sets or however many I tell them to.
Because of the patent taking so long, I basically went all through the prototype and testing phase with the machine shop and already made the first batch.
Old 12-21-2017, 09:12 AM
Adamo (catorce),
I'm rebuilding my 3.2 into a 3.4 and think your 964/993 squiters would be a good addition to my engine. Is there any need to modify or upgrade my oil pump to use the 2.5mm squirters?
Harold
Last edited by HaroldMHedge; 06-22-2020 at 06:37 PM.. Reason: Correct typo errors.
Old 06-22-2020, 04:36 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Well thought out design and execution. Many thanks for bringing these to market.
1986 Targa Guards Red
2021 MT09 SP
Old 06-24-2020, 04:30 AM
Puny Bird
Mark Henry's Avatar
Wish these had been available when I built my engine.
I'd have no issue with using loctite 640, I've used it since the early 90's, VW T1 gland nuts (flywheel), rod nuts, etc, my front A arm roller bearing inner races are "glued" on with 640. I've never had a failure when used properly.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-25-2020, 09:29 AM
What is their price point?
Dennis
Old 06-25-2020, 12:55 PM
