The flow characteristics are different because I have to maintain the same barrel OD as the factory, but the barrel INSIDE DIAMETER on mine is different because I'm using steel and I have to accommodate the threads for the cap. In my testing, if I used the same orifice as stock, my flow was slightly less. Bumping the orifice size up made the flow the same.
Oh, AVAILABLE NOW! I have 20 sets, already sold a set. |
Available RIGHT NOW! I have 19 sets left, 9 oversize and 10 standard. I can make more anytime, the machine shop is ready to produce another 20 sets or however many I tell them to.
Because of the patent taking so long, I basically went all through the prototype and testing phase with the machine shop and already made the first batch. |
Adamo (catorce),
I'm rebuilding my 3.2 into a 3.4 and think your 964/993 squiters would be a good addition to my engine. Is there any need to modify or upgrade my oil pump to use the 2.5mm squirters? Harold Last edited by HaroldMHedge; 06-22-2020 at 06:37 PM.. Reason: Correct typo errors. |
Well thought out design and execution. Many thanks for bringing these to market.
1986 Targa Guards Red 2021 MT09 SP |
Puny Bird
Wish these had been available when I built my engine.
I'd have no issue with using loctite 640, I've used it since the early 90's, VW T1 gland nuts (flywheel), rod nuts, etc, my front A arm roller bearing inner races are "glued" on with 640. I've never had a failure when used properly.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
What is their price point?
Dennis |
