Jamie,
From the photo, the COP's look like VW/Audi units to me. I agree, some datalogs are needed because you can not tell what is going on from just a dyno chart. In addition to possible ignition issues, without knowing AFR's, injector size, maybe he is running out of injector.
-Dennis 1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R |
There's a good point. 30lbs minimum for this setup
No physical quantity completely explains its own existence |
Even a really bad tuner would notice if he bottoms out the injectors...
Fuel pressure going out? But if the tuner had an 02 sensor he would notice that. It does look like the VW COP, I have those, I've hade one coil go slightly bad so it worked on idle and light throttle but was dead on full throttle. Something funky is happening around peak torque. The torque just drops and then picks up and drop again. Ignition or wiring.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
PRO Motorsports
Verified you're getting full throttle?
Hey, start with the basics.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Hello. First, none of these hot rod motors are not an oddball mix of parts. The only thing Porsche made were stock engines to pass emissions, and let your wife drive it to the grocery store in the rain safely . Even the race engines in 2 valve form from the factory were pretty conservative. So this is not your problem.
You need to check the basic set-up of the ignition system. Watch the ignition w a timing light through a complete run and see what is happening for starters. Your motor is down easily 60-75 ish HP from what it should be and the HP and Tqe curve swinging wildly indicate big woes. Look at the shape of any mildly cammed or even moderately cammed engine as your's and none make pk tqe then fall down 20 to get it back again, then fall again the same or more. This has nothing to do w cam, headers, port size, 85% thottle etc... Your tuner does sound a bit over his head to me if you are being told to drive it and enjoy it ( w 160 hp like a 2.0 L E) as it is obviously sick and you could do alot more damage. Who configured the motor,who made the wire harness, the tuner? Chk coil selection, and how it is set up, dwell times, are they smart coils, are they wires correctly? Can the ECU fire them directly or do you need an ignitor and if so was that selected properly, wired properly? Who also dyno's without AF data as none are present on your sheets? Or was there not another bung avail. as it was being used for data logging lambda? WHat do the data log look like on ignition timing and AF? Start there and consider getting a new tuner who has used these exact components and is familiar w these cars, especially if all these answers are not readily available . Kevin GAS Motorsport
Upland, CA |
Got this dyno sheet today also here is ITB info. Headers are Georges euro 1 and 5/8. Muffler is M&K. believe port size is 39MM.
Here is the info on the EFI ITB 1 ECU AEM Infinity 508 1 2 MAP Sensor, IAT & CHT Sensors, O2 Sensor 1 3 Fuel Pressure Sensor 1 4 Ignition coils for Coil on Plug- Bosch + S plugs 6 5 Fuel Injectors upgraded/rebuilt Bosch 6 6 Wiring Harness conn, hardware, smooth Sheath 1 7 Wiring Harness Fabrication, includes relay/fuse center 1 8 Fuel Pressure Regulator 1 9 Fuel- 6AN fittings and ethanol hose- Black 1 10 Fuel Pump - may not need 1 12 Crank,Cam position sensor (EPM) and mount 1 13 PMO 50MM ITB's. new manifolds, linkage, air cleaners 1 Assume fuel pump is set up for carbs. May need higher pressure pump. Do headers have O2 bung? yes Need intake port size at head Dyno tuning may not be needed. Call for discussion. Design harness - order connectors/parts Document existing EFI chassis wiring, clean up excess Install Harness in car + chassis wiring disassemble distributor, install cam, crank sensors Install ITB's, sensors on engine Fab hoses, mount fuel components Load software - sync timing, tune to start/ idle engine ![]()
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 01-18-2018 at 01:57 PM.. |
ITBS AND EFI PARTS
Headers and muffler, you can see the exhaust leak on left bank, that was fixed at time of EFI conversion
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) |
I have a 3.6 with ITB's, EFI, Flow through exhaust and Motec
-- engine itself was completely stock. From about 3000RPM to 7000RPM the torque curve was flat. On a very conservative tune I pulled 255 to the wheels. Your dyno chart doesn't look right. Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
There's clearly something wrong with this engine well beyond it being a mix and match of parts. What surprises me the most is that you say that the car feels ok when you drive it. There is a huge drop in torque at 4000 rpm and this should be felt as a clear drop in acceleration.
According to the torque plot, the car should feel more and more reluctant to accelerate as you approach 6000 rpm. Did it feel like this when driven after the dyno test? |
Could the Dyno be wrong?
I don't understand, is your fuel pump and regulator set up for carburetors? Carb fuel pressure should be around 6-8 psi, for EFI more like 45 psi. If you are at 6-8 it would be a miracle that it runs at all. Again, even a half-assed tuner would check fuel pressure if there was a problem....
The intake manifolds are 42mm at the head side? Are the heads 3.0? Or even 3.2 heads? Is 42mm correct?
Todd
'81 SC |
I would rather be driving
Any chance of wheel slippage on the drive roller? Or is this Dynapack a hub mounted?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
How about the clutch set up, how old is that? I've seen it on my 996tt where the car was showing no power on dyno (450rwhp) due to slipping clutch and flywheel issue. Clutch was swapped and all resolved ( 700rwhp)
Chain fence eating turbo
Dynapak should be hub?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, depending on mood ![]() |
+1.....on the fuel pump "set up for carbs" .....check your fuel pressure. if you are truly using a fuel pump that is designed for use with carbs, it will not provide the pressure/flow required for EFI. ....Easy to check fuel pressure with the Rasant /AEM system and is a standard step in the setup of the system. Any chance that you were data-logging, while on the dyno?
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 01-19-2018 at 07:56 AM.. |
Seeing an AFR trace for that dyno run might be interesting (assuming you were not data logging...if you have the full logs they would be even better).
That plot indicates AFR=12.3 @ 3788 rpm which tells me you don't have a carb fuel pump...likely very little would be getting through those injectors with the typical <10 psig carb pressure. Certainly not enough to make you super rich.
Jim 1974 914 Last edited by jd74914; 01-19-2018 at 11:51 AM.. |
Do you think you could hear this?
Sorry, ignore. Posted on wrong spot
1986 Targa Guards Red 2021 MT09 SP Last edited by brighton911; 01-19-2018 at 12:01 PM.. |
CPT KAOS
Subbed...Pull the muffler and air cleaners and see where it is. Seems like its choked. Jamie Novak is the man (continuous thanks for getting me rolling!!) follow his instructions and maybe find another tuner to look at it. Based on what you used (and aside from the ITBs being on the large side) I can't see that your physical setup is mismatched to a point of that little power.
Erik- RGruppe #743 Sports Purpose Garage CPTKAOS 313HP/265TQ(wheels)2150# |
Kartoffelkopf
(even better, have you got a plot or can you run a diagnostic capture, of the fuel pressure whilst you're driving? Not familiar with AEM, I presume it'll allow you to capture live data? And FPR?) ETA: As another thought, find out whether the AEM can auto-map itself. My old MBE ECU can be put into self calibration mode, used for coarse-grain trimming of the engine, which then gives you a suggested number of points on the 3D map which you can either accept outright, or use as a basis for trimming that area yourself, manually. If you were able to get some logged data from when you're driving, and where it feels "ok" to you, I'm sure there's a few folk on here who could read something revealing into that data. (Sorry, I'm not one of them!)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject Last edited by Spenny_b; 01-19-2018 at 01:46 PM.. |
Thread Tools | |
Rate This Thread | |
