CIS injector hole plugs, carbed engine
What is the best method to plug the injector holes in CIS heads ? (not MFI)
The engine is carbed.
Anyone make a suitable remedy ?
TIA
Rory
Old 05-03-2018, 06:21 PM
There are insulators to encompass the notch
I would contact PMO for a set.
Bruce
Old 05-03-2018, 07:13 PM
Bruce
That's a good idea Bruce I'll call them.
Thank You
You've brought something to my attention.
The heads I'm working with have a hole that extends from the top surface
of the head directly into the intake port aimed at the valve.
It is a ~14mm hole, not a notch.
The hole is smooth, not threaded.
Old 05-03-2018, 07:39 PM
On the 2.4 CIS heads, you can run a tap into the hole and then plug them just like you do with the MFI heads.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 05-04-2018, 04:25 AM
Tom hit it, the 73 CIS heads had a pressed in aluminum sleeve where the MFI injectors went.
once removed, there is no threads.
That was an only year application.
Bruce
Old 05-04-2018, 05:47 AM
