				CIS injector hole plugs, carbed engine
			What is the best method to plug the injector holes in CIS heads ? (not MFI)
				The engine is carbed. Anyone make a suitable remedy ? TIA Rory  |
			There are insulators to encompass the notch
	I would contact PMO for a set. Bruce  |
 Thank You You've brought something to my attention. The heads I'm working with have a hole that extends from the top surface of the head directly into the intake port aimed at the valve. It is a ~14mm hole, not a notch. The hole is smooth, not threaded.  |
			On the 2.4 CIS heads, you can run a tap into the hole and then plug them just like you do with the MFI heads.
	Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process  |
			Tom hit it, the 73 CIS heads had a pressed in aluminum sleeve where the MFI injectors went.
					once removed, there is no threads. That was an only year application. Bruce  |
