is this okay
Well
I think this workmanship kinda make me worry..
I took some pic of my rebuilt done connected Rod
what do you think this is an acceptable ?
Old 02-27-2018, 05:22 PM
Originally Posted by frankoporsche View Post
Well
what do you think of this ?,it is an acceptable ?
Old 02-27-2018, 05:29 PM
Kartoffelkopf
Spenny_b's Avatar
Well, I'll leave it to the pro's here to cast verdict....suffice to say it looks nothing like the rods I had done with 22mm small-ends, nor the new Carrillo rods that are now in my engine....(no, I wouldn't be happy either)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Franko,
Who did the work on those rods?
Old 02-27-2018, 07:34 PM
Originally Posted by Catorce View Post
Franko,
ollies
just about all the rod has this small lack of material after the bearing being sized
the worst one is .127mm bigger ..I took two measurement from zero and 90 deg. boy they are out of round...I cant believe it
5 out of 6 are fine
Old 02-27-2018, 09:25 PM
Kartoffelkopf
Spenny_b's Avatar
Franko, have you spoken to them directly?
Old 02-28-2018, 04:57 AM
Chain fence eating turbo
It looks like the bushing parting line.
Those bushings are pressed in, then honed to the exact wrist pin.
Are you sure they are out of round? They takes a special bore gauge to make that call.
Dial calipers is not accurate enough due to angular variability.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-28-2018, 05:49 AM
what's your concern? They look find to me. But if you're worried, take some pics of them all and call them and talk to Tim or Zack. They'll probably have you email them the pics... and if they are concerned as well, you can send them back.
1987 Porsche 911 Carrera Coupe
Old 02-28-2018, 06:20 AM
For those that don't know, Franko is a retired machinist, although not automotive. He is capable of making the measurements.
Franko I suggest you call Ollies on this one.
Old 02-28-2018, 07:23 AM
Then why the questions?
If it's out of round, it's out of round, and warranty work.
Old 02-28-2018, 07:29 AM
Hey Tippy
I didnt question about the wrist pin bore is out around...I question about the workmanship is an acceptable ?
later in the day after I posted the first time...I took the measurement just to make sure is okay to use as is.. one side is good and other side of the wrist pin is larger
I will give the shop a call...Thank you for you input
I dont wanted to badmouth about the machine shop...we all do make a mistake ..
Old 02-28-2018, 08:40 AM
Oh, ok. Being out of round is big no-no of course, but the parting line is a question of mine too.
My bushings were solid.
Old 02-28-2018, 09:56 AM
Under the radar
Trackrash's Avatar
What rods are these? Some bushing sizes are only available in the split style? Did you test it with a wrist pin?
Let us know what Olies has to say.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-28-2018, 10:19 AM
Thank you for your understanding ..
I just spoke to Zack and he said to sent back the rod for rework..he think it may have debris inside the bushing cause to over size...it is no big deal...
as far as the bushing ..those bushing in my connected Rod are standard shop supply
to have the solid bushing install you have to make request
Old 02-28-2018, 10:26 AM
Those bushing is recommend by their shop for racing or under 3.2L
only time they use the solid bushing if your piston rod need to be offset or the customer prefer
Old 02-28-2018, 10:31 AM
that's good to know.. though I wonder why you WOULDN'T want a solid bushing?
Old 02-28-2018, 11:53 AM
I was not aware of an option....
Old 02-28-2018, 12:52 PM
Canyon makes them for the 911 rods...went with them for my rods when rebuilding
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 02-28-2018, 04:26 PM
Good to hear they're making right!
Old 02-28-2018, 05:20 PM
Ingenieur
A bushing is thicker, so you have to bore out the small end bore. That makes it somewhat weaker. Probably not the best thing on 95mm or larger bores with a 23mm pin.
Old 03-01-2018, 08:31 AM
