Temperature when Driving
Had my original 6 engine totally rebuilt too a 2.2 with E cams ,when the car is up to temperature the temp gauge looks quite high as in the picture below,I’ve been told by another member that’s how there car runs,when sat in traffic the temp goes up a bit more as in the first pic ,is the car running to hot and what if anything should I do
![]() ![]() Thanks Brian |
well.. this depends. What's the temperature outside??
What sort of driving are you doing.. stop n go.. highway? Do you have an oil cooler? aftermarket? original? if so.. does the fan kick on? is your engine shroud properly setup and the fan turning properly? How many blades are on your fan? I've heard that on older cars, updating to a newer style fan blade can help improve cooling. I've also heard that certain oils will run hotter than others.
1987 Porsche 911 Carrera Coupe |
Under the radar
What car is it in? What gauge is that? What sender are you using? What is your intake? Carbs?
I would use an IR thermometer on the oil tank to see what your oil temp is.
Indicates you are running hot,checked my spare gauge insert which has the increments shown right @ the top of the insert ,you need to turn the whole gauge to see it,mine is a 911 insert and your gauge appears to be 914 or 914/6 ,don't know if these marks are there on those inserts.
However looks like you are atleast running 120C which is bloody hot,is your sender ok,I go new on these cause its cheap insurance. Good luck.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
