Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
samuraj's Avatar
throttle problem ????
2001 530 ....starts only with throtle open,
idles fine
when push gas pedal engine dies.
car mowes forward only with throttle half open...
please help
happen after gas fill up at station
2001 530i black
2005 dodge ram hemi sport
P1445 Big Hawg
Old 10-12-2004, 04:55 PM
samuraj's Avatar
last minute update: ses light on
coolant low
new radiator (10000 miles old)
2001 530i black
P1445 Big Hawg
Old 10-12-2004, 05:58 PM
budmur's Avatar
Send a message via AIM to budmur
Is it smoking?
Low coolant and really poor performance are a sign of a blown head gasket. The engine starts to suck water and it runs bad. Other symptions are:
1) Bubbling in coolant overflow
2) Milky white engine oil
3) Severely fouled spark plugs
4) Lots of white exhaust, or even antifreeze dripping from the exhaust
If you get it fixed quickly, it's generally not catastrophic. The longer you wait, the higher the repair bill will be.
This isn't caused by bad gas. Sometimes these just go bad.
Old 10-13-2004, 05:42 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Im kind of thinking the same thing...
Maybe you should do a compression check. This can usually indicate if you have a blown head gasket. and run the codes on the car to see if there is anything wrong
Old 10-13-2004, 10:39 AM
samuraj's Avatar
time to visit dealer......again
2001 530i black
P1445 Big Hawg
Old 10-13-2004, 05:12 PM
samuraj's Avatar
verdict:
camshaft pulse gener.......$242.60
2001 530i black
P1445 Big Hawg
Old 10-19-2004, 04:05 PM
budmur's Avatar
Weird that you got the low coolant light. Sometimes cars don't make much sense.
Glad you got it back and that it wasn't something more serious.
Old 10-19-2004, 05:14 PM
a bad cam sensor wouldnt cause you to lose coolant..
Old 10-20-2004, 06:32 AM
samuraj's Avatar
cool... so nothing more to worry about, low coolant make me think a little.......... now I fill better, thanks!
2001 530i black
P1445 Big Hawg
Old 10-20-2004, 06:03 PM
samuraj's Avatar
one more think.....car it`s a beast now !!!!
2001 530i black
P1445 Big Hawg
Old 10-24-2004, 05:50 PM
