Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
E39 Front and Rear Window Trim Replacement
I will soon own a E39 that showed deterioration of both front and rear window trim. I see that PP stocks the trim for the front window. Is it the same for the rear window and is this a fairly easy job that does not require special tools?
Old 03-30-2012, 04:04 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
It isnt the easiest to remove the trim without bending it. The front trim pieces will not be the same as the rear.
If you give me your VIN, I can look up the correct pieces for the rear.
Old 04-02-2012, 07:46 AM
