LinkBack | Thread Tools | Rate Thread |
Is it possible to adjust preload on Ohlins front shock without removing it?
This is a BM842
It seems impossible to me, am I missing something? Also, why does the sleeve where the castle nuts on the shock body turn (see pic - section outlined in red)? I had to hold the shock in a vice and use a strap wrench while I adjusted the preload. ![]() |
Yeah, I know how to do it. I couldn't get the spanner in place while the shock was on the bike and even if I could the sleeve would have just turned, not the upper nut.
Wondering if anyone knows a trick. |
Ohlins preload
I know, I've just been trying to solve the same problem. There is no room for the spanners.
Check out Traxxion Suspension preload collars. They come with a torrington bearing to ease adjustment. The TTX is the correct one for this shock. Their vendor Trackside Suspension has them listed. I believe the sleeve is loctited on. You could check with Jim at Pro-Pilot , he supplied my shocks and was very helpful. Also look at nylon tipped set screws for the collar so as not to damage the threads. Last edited by boxerebel; 09-23-2019 at 08:46 AM.. |
Excellent tip boxerebel! Cool product.
You can add an Ohlins preload adjuster to it. When I had pro Pilot do my 99 he added it. My BCR has it as well from Jeff having it done.
Ohlins preload
Yes the part # for that is 21681-02. Pro-Pilot quoted me $260 US last year.
I was concerned that since it was hydraulic it might not hold up.I guess yours has Vette Racer , good to know. |
sɹǝʇndɯoɔ sǝʇɐɥ
Yeah I just went through something similar with a similar model for my airhead. Stupid stupid design. One side i could only increase preload while I could only decrease on the other and the hell if I'm going to remove them to adjust it. I returned them and went with something else.
Mike '07 R1200S |
Registered Agitator
My rear Ohlins remote preload adjuster has crapped out twice. Fortunately my spring rate is perfect for my weight with no preload. The front is perfect so I never had to adjust it.
Thread Tools | |
Rate This Thread | |
