Plugged tire safe?
Is a plugged tire safe, or do I need to replace as soon as possible? I had a screw in my front tire - a brand new Michelin Road 5 - and would rather not buy another.
I’ve searched this but see varying opinions. Has anyone ridden one for an extended amount of time? The hole patched well, and isn’t in an awkward spot.
Old 06-01-2020, 06:00 PM
"A" "A" is offline
el Cheapo
"A"'s Avatar
Safe enough for me when I know it's plugged correctly and I am operating my bike.
I don't know how well you did your plugging nor how you ride your vehicle.
It's always at your own risk.
When in doubt, throttle out.
Brakes, who needs them; they only slow you down.
Old 06-02-2020, 12:14 AM
Tirefriar's Avatar
My personal opinion is for few hundred dollars I’d replace the tire. The only reason you’d plug it on a car is because you have 3 other tires for load distribution plus there’s a spare (usually) if the plug leaks ;-)
Old 06-02-2020, 12:17 AM
I'd ride with a plug in a rear tire. I'd swap out the front at my first opportunity. It's a bummer, those things are $$$.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 06-02-2020, 01:19 AM
I plug my tires as required, so far no issues with any of them. Most extreme was on my GS during a trip and had three plugs in one hole but did make the rest of the trip with, again, no issues.
Like Jim I just let the rears go, fronts I'd rather change.
I haven't heard of plugs blowing out, leaking maybe.
Old 06-02-2020, 03:20 AM
Used patch/plug at least 8 times... never a problem.
Old 06-02-2020, 05:23 AM
Andrew Moore
I have no issues with riding with a plug, but I do closely monitor the air pressure. If I had a plug with a leak, I would replace the tire.
Old 06-02-2020, 05:40 AM
Registered Agitator
sgoodwin's Avatar
Absolutely unsafe, you'll die under an 18 wheeler & be run over by 100 cars behind it.
Do I do it? Fuk yes, tires are expensive & I'm a cheap azz baztard. In reality I got about a 10% failure rate with just plugs, 0% with plug patches. Sometimes you just have no option but a plug to get home. Working on a couple thou in the rear on my zx, I do try to keep it under 200 though.
Old 06-02-2020, 11:41 AM
So I think I’ll just bite the bullet on this one. Thanks fellas.
Old 06-02-2020, 05:03 PM
Originally Posted by bykemike View Post
i plug my tires as required, so far no issues with any of them.
+1
BMW R1150sR - Project Touring Bike
Ducati Hyperstrada - Mountain Road Slayer
Porsche 914-6 Vintage Race Car
Porsche 944 S3S (S3 Studie)
Old 06-02-2020, 09:45 PM
+1
When things go wrong the money you are talking for a new tyre is peanuts.
XR1000
K1200r Sport
XT660
Tiger 955
R1100s
Old 06-03-2020, 11:47 AM
tm1100s's Avatar
Patch to get home, replace ASAP.
Not mine, but who remembers this one?
tm
(R12, R11, R1) + 00 then S, S, /7
Old 06-03-2020, 01:21 PM
The other pic that should be shown is Sergio’s bike on the trackstand that Tuna found on the roadside! LoL
Mike
'07 BMW R1200S
'99 Ducati 996
'09 Husky TE450
Old 06-03-2020, 07:26 PM
tm1100s's Avatar
I have that one, too. Gimme a few minutes.
Old 06-03-2020, 07:42 PM
tm1100s's Avatar
tm
Old 06-03-2020, 09:01 PM
Registered Agitator
sgoodwin's Avatar
Best use of a tube tv I've seen in a while.
Old 06-04-2020, 05:31 AM
terrym's Avatar
Fixed it for you.
Terry
2016 Cayman
2004 R1150S
Old 06-04-2020, 08:27 AM
Send a message via AIM to tomvv11
Ha, I thought it was a 1200S pannier that was extra deep because of all the space between seat and tire.
Old 06-04-2020, 12:49 PM
R1100s
I've been riding with a plugged rear tyre for about 5,000kms, but would not risk front. They were new tyres,...Murphy's Law!
2009 HP2 Sport (sold)
2006 R1200s Remus exhaust, K&N, ilmberger carbon hugger, Ohlins, ABS, Heated grips, Wide Rear Wheel
2006 Subaru WRX STI S204 #318 / 600
Mercedes-Benz B-Class B180 BlueEFFICIENCY
Old 06-04-2020, 02:44 PM
Registered Agitator
sgoodwin's Avatar
Same reason I'm running a plugged rear on the zx. It had less than 100 miles when I picked up a screw. Had a bud with a 929 with 5 plugs in his rear tire. He wore it out with no problems.
Old 06-04-2020, 02:51 PM
