Plugged tire safe?
Is a plugged tire safe, or do I need to replace as soon as possible? I had a screw in my front tire - a brand new Michelin Road 5 - and would rather not buy another.
I’ve searched this but see varying opinions. Has anyone ridden one for an extended amount of time? The hole patched well, and isn’t in an awkward spot. |
el Cheapo
Safe enough for me when I know it's plugged correctly and I am operating my bike.
I don't know how well you did your plugging nor how you ride your vehicle. It's always at your own risk.
When in doubt, throttle out. Brakes, who needs them; they only slow you down. Last edited by "A"; 06-02-2020 at 12:16 AM.. |
My personal opinion is for few hundred dollars I’d replace the tire. The only reason you’d plug it on a car is because you have 3 other tires for load distribution plus there’s a spare (usually) if the plug leaks ;-)
I'd ride with a plug in a rear tire. I'd swap out the front at my first opportunity. It's a bummer, those things are $$$.
Jim Moore Jax, FL '01 R1100S '07 CBR600RR |
I plug my tires as required, so far no issues with any of them. Most extreme was on my GS during a trip and had three plugs in one hole but did make the rest of the trip with, again, no issues.
Like Jim I just let the rears go, fronts I'd rather change. I haven't heard of plugs blowing out, leaking maybe. |
Used patch/plug at least 8 times... never a problem.
Andrew Moore
I have no issues with riding with a plug, but I do closely monitor the air pressure. If I had a plug with a leak, I would replace the tire.
Registered Agitator
Absolutely unsafe, you'll die under an 18 wheeler & be run over by 100 cars behind it.
Do I do it? Fuk yes, tires are expensive & I'm a cheap azz baztard. In reality I got about a 10% failure rate with just plugs, 0% with plug patches. Sometimes you just have no option but a plug to get home. Working on a couple thou in the rear on my zx, I do try to keep it under 200 though. |
So I think I’ll just bite the bullet on this one. Thanks fellas.
BMW R1150sR - Project Touring Bike Ducati Hyperstrada - Mountain Road Slayer Porsche 914-6 Vintage Race Car Porsche 944 S3S (S3 Studie) |
When things go wrong the money you are talking for a new tyre is peanuts.
XR1000 K1200r Sport XT660 Tiger 955 R1100s |
Patch to get home, replace ASAP.
Not mine, but who remembers this one? ![]()
tm (R12, R11, R1) + 00 then S, S, /7 |
The other pic that should be shown is Sergio’s bike on the trackstand that Tuna found on the roadside! LoL
Mike '07 BMW R1200S '99 Ducati 996 '09 Husky TE450 |
Registered Agitator
Best use of a tube tv I've seen in a while.
Terry 2016 Cayman 2004 R1150S |
Ha, I thought it was a 1200S pannier that was extra deep because of all the space between seat and tire.
R1100s
I've been riding with a plugged rear tyre for about 5,000kms, but would not risk front. They were new tyres,...Murphy's Law!
2009 HP2 Sport (sold) 2006 R1200s Remus exhaust, K&N, ilmberger carbon hugger, Ohlins, ABS, Heated grips, Wide Rear Wheel 2006 Subaru WRX STI S204 #318 / 600 Mercedes-Benz B-Class B180 BlueEFFICIENCY |
Registered Agitator
Same reason I'm running a plugged rear on the zx. It had less than 100 miles when I picked up a screw. Had a bud with a 929 with 5 plugs in his rear tire. He wore it out with no problems.
