I checked the cams and the right side (sitting on the bike) is down at 6 oclock. Could you have possibly had the engine on TDC on the exhaust stroke when you started this project? There is two tdc's, one compression, one exhaust. If you accidently started on the exhaust tdc then when you rotated the engine 180 degrees to do the other side, you would have everything 180 out and hit valves. Please note. I am not a expert and I do f&^%$ up sometimes. I would just like to help and would come over if you didnt live a hundred miles away. I am sure you will get it soon anyways.
well, tdc is both cylinders at the same time. on one side it is overlap, the other combustion. so, at any tdc, one will be 12, the other 6. given both plugs and injectors fire every rotation, it makes no difference.
if you set them both to 12 at any tdc, you'll have a big bang boxer. i've been curious to try that, just not on my bike.
'89 851 '97 600m '65 Hunnybunny '05 Little man |
Yikes, that'd really wind the crank up. (and the crankcase pressure spikes) Would be interesting to see what happened to traction. The pulses on a regular boxer are already spaced and sized about like a big-bang L4, so this would be new.
Are you sure you were tdc at all on initial install?
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Davidb2.
thanks for the look maybe we can have a bite at pier 23 in SF when Jenny and Rattus get their,( see thread). I'll get this beast running by this weekend and will ride up their to smooze with harold and jean. Maybe you can hit the Norcal- Socal ride April 3. thanks jw Brad, Thank you very much for your help. ![]() If you check arround you will find that harleys make that sound ![]() all kidding aside, thanks for the advice and patience. jw Roger, at this point who knows. more than likely I wasn't even near TDC. What I know now is that I will be or I will have an expensive planter box for my house ![]() Thanks for your help. CYA Jeff
Riding, releases my mind from the tyranny of petty things. Thats why i ride. 2003 Boxer cup Rep 2113 Multistrada S Touring 95 R100RT Classic, a keeper |
Hey Jeff;
e-mail me on the details of you problem, And about the ride on April 3 ? Maybe I will ride down!!!!!!
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, ![]() ![]() |
EZ,
My problem is touching my bike when I shouldn't. thanks for the offer. see you April 3,(see email) CYA Jeff
Hi all,
Well I got the sprockets aligned and they seem to work well. spun the engine from the front pulley clockwise about a dozen times. Everything worked will, nothing moved, not nasty metal sounds. buttoned the heads up and put on the tank, charged the battery, set the motronic, and pushed the starter...OUCH METAL SOUNDS... The bike didn't start,(thank god). After some thought and a head butt to the wall, I pulled the valve covers, took off the tank, sprocket covers, and pulled the plugs. I then hit the starter again and a lite metal sound came from the chain galleys,(both sides), or the intakes very softly, I could not tell. ![]() To review: in TDC, left sprocket cam notch at 12 o'clock, right sprocket cam notch at 6 o'clock. sprocket will advance cam 9 degrees. Sprockets in alignment. I will more than likely adjust the valves after I check for misaligned chain rails,(check already), frozen tensioners, loose parts that don't belong, a compression check. As I have said before, this sucks Round #2 tomorrow pray for me or have a beer. Jeff
Got a beer in my hand right now for ya Jeff!
Hope you get it working soon. Ya know, so I can borrow it next time I am over there ![]() Matt
RIP Jeff Williams; RIP Brad Zimmerman 1989 K100RS - White/Blue, Remus; 1999 R1100S - Mandarin Orange, Remus, Ohlins; 2007 G650XCountry - Black/Silver, iStorm Luggage - Wilbers 75mm Lowered shock for the wife!; 2003 BCR #57 - Jeff's bike ; 2009 G477X - Akrapovic, WP Trax, SpeedBrain Goodies 2000 ///M5 - Custom Black & Blue, Dinan goodies |
Hi all,
well here is the story, I got the thing running. one cylindar was 180 off,(which fulfilled Brad Blacks dream of the big bang,single strock bike ![]() I started it and heard metal sounds when I started the bike but not when running. I looked in the hole which show you TDC and looked at the flywheel. 3 teeth were broken then I listened to the starter, it just spun with out moving the flywheel. Bottom line: lost a flywheel and starter, ouch. Best of all called my local BMW shop ,(I have always heard a metal 'klunk' when the bike failed to start and kicked back), and they said that they did not know if this would be under warranty I would have to bring the bike and they would decide the issue. The problem is that I'm over 200miles away. If they didn't warranty the problem it would increase the over price of the mishap by at least 50%,(getting the bike their and back etc). So I guess I will probly fix it myself as penance for being so stupid. Thank you one and all for your insight and thoughts. Jeff
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
"So I guess I will probly fix it myself as penance for being so stupid.
Thank you one and all for your insight and thoughts." Its not penance. Its the cost of your BMW diploma from the school of hard knocks! I've got lots of those diplomas.
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
I might have some parts if they fit.
ckcar,
i like the way you think ![]() It still hurts. ![]() Davidb2, thats a super lite bike you got there ![]() Jeff ps do you take cash ![]()
Jeff, glad to hear you're almost out of the woods on your project. I had to laugh a bit though at the irony of a dentist working on a Beemer and ending up with three missing teeth...
![]() davidb2....is that the new German version of the Mar's rover...?
Scott '98 R1100S - Triple Clamps, 10mm Shortened Telelever 2013 KTM 990 SMT, 2008 KTM 990 SDR |
that is whats left of a 2002 GS, It is the donor for my cruiser.
Scott,
hahaha, I think I'm going for implants ( .) (. ) I will try to get this together asap so we can ride my friend. cya davidb2, the starter may work but I don't know about the flywheel will email you tomorrow Jeff
so it tore the teeth off the ring gear as both cylinders came up to compression at the same time?
or was that not related? sounds pretty wild.
Brad,
yep, the single lunger was too much for the starter and flywheel, great sound, you must try it sometime. ![]() ![]() ![]() Is the started shot or can the gear at the end be replaced. Are all the flywheels the same on the S, GS? What about the starters CYA Jeff
Quick look in the ETK, shows the starter is the same for looks like most 94+ R's. The flywheel I guess is called a clutch housing, and is the same for the GS from 99+ and the R/RT/RS from 01+.
Starter part # is 12 41 2 306 700 Clutch housing art # is 21 21 7 666 246 Price listed for starter is 223, price for clutch housing is 153. Unfortunatly, I have no idea what currency that is, and if its dealer or MSRP.. but atleats shows the difference. LOL Hope this helps you out... Goodluck Jeff ![]() Matt
Heres a diagram of the starter.
![]() And heres the parts list for it. ![]() Matt |
Matt, thanks for the ETK disk. It really comes in handy when you need part numbers and diagrams. I was able to order parts easily, for the last repair I did, using the part numbers from the ETK. Here is the other info Jeff will need for the ring gear (clutch housing).
![]() and the parts list to go with it too: ![]() Jeff, while your in there that far you ought to look into a heavy duty clutch replacement. You know you you love to do those 1st and 2nd gear wheelies.... ![]()
Scott '98 R1100S - Triple Clamps, 10mm Shortened Telelever 2013 KTM 990 SMT, 2008 KTM 990 SDR Last edited by motoyoyo; 02-22-2004 at 11:09 AM.. |
Thread Tools | |
Rate This Thread | |
