repoe3's Avatar
online source for small indicators...
some ahve asked about the rear indicators used on mine and other's bikes. these things rock at $15 for a pair. they are bright and if installed properly will clear the bmw system bags...
http://www.cyclegear.com/spgm.cfm?L1=2&L2=&L3=&L4=&item=MRX_AIN1_G
and they have these smaller ones as well..
http://www.cyclegear.com/spgm.cfm?L1=2&L2=&L3=&L4=&item=MRX_DW1_G
repoe3
I couldn't repair your brakes, so I made your horn louder.
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 04-16-2004, 08:58 AM
Moybin's Avatar
repoe3: those look sweet. What kind of bulb do they use? LEDs?
'99 Black SA "OBSSSN" - gone but not forgotten.
Not all good technology is new, not all new technology is good.
.........Purple is Satire.........
Old 04-16-2004, 09:08 AM
repoe3's Avatar
regular filament bulb. they are as bright if not brighter than the bulbous stock units on the rear.
repoe3
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 04-16-2004, 09:26 AM
Barback King
Rapid Dog's Avatar
I hope they are better than the Locjhart Phillips China junkers...I bought a set aand the practicaly crumbled on installation. The bulb socket was so tinny that they warped...real crap.
R11S CNC BARBACKS
Old 04-16-2004, 09:45 AM
repoe3's Avatar
yes they are much better than those. firbolter has a set and i have two, one on the S (removed since reinstalling the LED's in the brake light housing) and one on the R6.
repoe3
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 04-16-2004, 09:49 AM
You want small? Check this out.
http://www.watsendesign.com/Products/products.htm
Philip
Old 04-16-2004, 10:05 AM
Firebolter's Avatar
Cyclegear is the same store I bought them at in Tucson.....Going to Tokyo end of May, what kind of good stuff should I pick up from there? They have all kinds of cool stuff we don't!
2014 BMW F800GSA
2013 Berg TE300
2007 KTM 525EXC
2006 Husqvarna SM610
2011 Beta 300 Trials/74 Suz RL250/71BSA250Trials
Old 04-16-2004, 10:16 AM
Don Ro's Avatar
Thumbs up Cycle Gear sig. lites - BTDT...
Yeppers...got those sig. lights on mine, repoe3. Bright, too - 23watt lamps, as I recall.
Hot tip 'o day: Sign on to Cycle Gear's web site email list to receive their great sales notices. I bought some Galfer items at 30% off as well as these sig. lights for $1.98/set. 'Bought 6 sets.
Comparo of sig. light body size:
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 04-16-2004, 10:20 AM
Don Ro's Avatar
One more note: Spare bulbs at Honda dealers. P/N 122-9601. $1.96 ea.
Best,
Don
Old 04-16-2004, 10:25 AM
Nitro's Avatar
How do they istall?
Memento Audere Semper
Old 04-16-2004, 10:41 AM
repoe3's Avatar
guess you could install them on the stock mounts, but i actually cut off the stock mounts and fab'd tabs on my plate mount for the them, so they were much lower and more inboard, next to the top bolts holding the plate on the bike. you will have to run wires through a heat resistant sheathing between the exhasut pipes if you relocate them, but if you install on the stock mounts, it would be plug-n-play.
repoe3
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 04-16-2004, 11:00 AM
Don Ro's Avatar
Here you go, Nitro - you crazy lad.
They're not unlike most lights to install - IOW's, easy as pie.
I did hog out the hole in the stock bracket, however, to receive the threaded light housing shaft.
Ran the stock affixing screw through the cleat I made and into the bracket.
No mods I made will prevent using the stock light.
Changed rear turn signals...(pics)...
Don
Old 04-16-2004, 11:03 AM
Send a message via ICQ to fredman
I reckon the Kellerman micro 1000 are by far the prettiest,and very bright for their size.they run a 5w halogen globe.I had to put a couple of big resistors inline to get the flash-rate right.The four 10w ceramic resistors are actually bigger than the blinkers.
Old 04-19-2004, 01:59 AM
