OT-sortive...more about intake talk
http://www.sportrider.com/tech/146_9912_ram/
interesting article about ram air and its benefits..figure this has to carry over to the S and the induct...not that i am fishing or anything. repoe3
I couldn't repair your brakes, so I made your horn louder. 2009 GSXR 750 2004 Tuono 2004 R1100SBX |
Hey Repoe3;
Good info. I am wondering what gains you would get with the In-Duct ?
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
I really like SportRider, but the article is pretty much fluff. First, it's no secret that ram-air works, so what's the point. 2nd, there is NO reason to believe that shooting a compressor source in the area maps well to gneralized hi speed airflow. 3rd, there's even less reason to believe that the specific locations the was directed at would correspond to the high and low pressure points generated by actual airflow over the nose of the specific bike.
So, it says: More air = more power. Big suprise. Again, I like SportRider, and applaud their efforts, but a competent Jr. High science teacher could use this only as an example of bad science, procedure, and assumptions. Cool idea, but utterly useless. And who knows what the induct gains are. The bikes do better at high speed roll-ons, but the benefit naturally doesn't show up on the dyno, and thus the gains aren't readily quantifiable. We shouldn't confuse a lower restriction and improved intake, with a real ram air system. Again, that's no knock at the product, which I use a like, I'm just pointing out the folly of expectding dyno numbers for it.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Re: OT-sortive...more about intake talk
Check out BMW Forums at http://www.bmwforums.net/forums/index.php Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out, and screaming,"'WOO HOO! What a ride!" |
doh...
repoe3
I'd sure like to see the at-speed airbox pressures for the induct vs. stock...it could be quite a selling point.
![]() best, Dave stock intake.
call PI research and get their data aquisition setup andlets us know. i am actually still running the stock intake as well. had it on the last S and it was a part of the total package to say the least.
repoe3
Good point DS.
I thought that was once published, at least on a thread. I expect to install a MAP sensor on the LM1 and measure it myself this summer.
I went ahead and put the chip in yesterday. It was so nice and cool, I figyred if I wasn't riding, I should be working on Rojo Diablo. You are gonna like the ride Tuesday!
I'm not gonna put the Rene airkit on till the 900 miles point. I want to ride it like this for awhile to see how much of a seat-o-the-pants difference it makes. So for now, clipped wire, high flow air cleaner, box derestricted, Rene pipes and chip. Man does it feel good. Pulls hard in 2/3 from 7-9 with light front wheel. As I changed out the stock paper element air filter for the Evoluzione, I was looking at my ram air intake track. From the fairing, the two inlets feed up to openings on the inside of the frame rails. From the airbox( or Airkit when I install it) there is a 2 legged rubber fitting that connects the bottom of the airbox to the two ram air tracks. The legs fit inside and are about 1/4 inch thick rubber. I was thinking it would be probably benificial to make a carbon fiber track that fit over the ram inlets vice inside, freeing up more space and not slowing down the flow as the air compresses into the small rubber legs enroute to the airbox. Damn if I were still in Hawaii, my buddy Steve would lay up a form for me. Those guys that build boats know how to form one off pieces fairly easy..... What'ya think?
2014 BMW F800GSA 2013 Berg TE300 2007 KTM 525EXC 2006 Husqvarna SM610 2011 Beta 300 Trials/74 Suz RL250/71BSA250Trials Last edited by Firebolter; 05-09-2004 at 11:53 AM.. |
sounds good. hopefully the weather and schedule will hold out this week. looking forward to taking stinky winky, i mean rojo diablo out for a ride.
repoe3
Firebolter - The early Mille air boot available from AF1 does exactly what you want to do. I made up a couple gaskets from rubber mat to seal between the frame openings & the boot horns as there is a slight gap there. Works great!
John B. 03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5 90 535im & 95 525i Touring 65, 66 Alfa Romeos |
Lennie www.boxer-performance.com 1998 R1100S Yellow is the best (now departed from my life) |
bikpaintr, thanks for the tip! I'll check that out.
repoe, stinky winky? Man you can talk bad about my sister, even my girlfriend but when you start dissin my ride, thems fighting words boy!!!
2014 BMW F800GSA 2013 Berg TE300 2007 KTM 525EXC 2006 Husqvarna SM610 2011 Beta 300 Trials/74 Suz RL250/71BSA250Trials |
