repoe3's Avatar
OT-sortive...more about intake talk
http://www.sportrider.com/tech/146_9912_ram/
interesting article about ram air and its benefits..figure this has to carry over to the S and the induct...not that i am fishing or anything.
repoe3
I couldn't repair your brakes, so I made your horn louder.
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 05-07-2004, 09:06 AM
EZ-RIDER's Avatar
Hey Repoe3;
Good info. I am wondering what gains you would get with the In-Duct ?
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 05-07-2004, 09:16 AM
roger albert's Avatar
I really like SportRider, but the article is pretty much fluff. First, it's no secret that ram-air works, so what's the point. 2nd, there is NO reason to believe that shooting a compressor source in the area maps well to gneralized hi speed airflow. 3rd, there's even less reason to believe that the specific locations the was directed at would correspond to the high and low pressure points generated by actual airflow over the nose of the specific bike.
So, it says: More air = more power.
Big suprise. Again, I like SportRider, and applaud their efforts, but a competent Jr. High science teacher could use this only as an example of bad science, procedure, and assumptions. Cool idea, but utterly useless.
And who knows what the induct gains are. The bikes do better at high speed roll-ons, but the benefit naturally doesn't show up on the dyno, and thus the gains aren't readily quantifiable. We shouldn't confuse a lower restriction and improved intake, with a real ram air system. Again, that's no knock at the product, which I use a like, I'm just pointing out the folly of expectding dyno numbers for it.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 05-07-2004, 09:32 AM
shannonnunley's Avatar
Re: OT-sortive...more about intake talk
repoe3
You passed up a perfectly good opportunity to breathe some life into the induct thread?
Check out BMW Forums at http://www.bmwforums.net/forums/index.php
Life should NOT be a journey to the grave with the intention of
arriving safely in an attractive and well preserved body, but rather to
skid in sideways, chocolate in one hand, martini in the other, body
thoroughly used up, totally worn out, and screaming,"'WOO HOO! What a ride!"
Old 05-07-2004, 09:37 AM
repoe3's Avatar
doh...
repoe3
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 05-07-2004, 09:42 AM
I'd sure like to see the at-speed airbox pressures for the induct vs. stock...it could be quite a selling point.
best,
Dave
stock intake.
Old 05-07-2004, 09:56 AM
repoe3's Avatar
call PI research and get their data aquisition setup andlets us know. i am actually still running the stock intake as well. had it on the last S and it was a part of the total package to say the least.
repoe3
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 05-07-2004, 10:33 AM
Good point DS.
I thought that was once published, at least on a thread.
I expect to install a MAP sensor on the LM1 and measure it myself this summer.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 05-08-2004, 09:36 AM
Firebolter's Avatar
Cool repoe
I went ahead and put the chip in yesterday. It was so nice and cool, I figyred if I wasn't riding, I should be working on Rojo Diablo. You are gonna like the ride Tuesday!
I'm not gonna put the Rene airkit on till the 900 miles point. I want to ride it like this for awhile to see how much of a seat-o-the-pants difference it makes. So for now, clipped wire, high flow air cleaner, box derestricted, Rene pipes and chip. Man does it feel good. Pulls hard in 2/3 from 7-9 with light front wheel.
As I changed out the stock paper element air filter for the Evoluzione, I was looking at my ram air intake track. From the fairing, the two inlets feed up to openings on the inside of the frame rails. From the airbox( or Airkit when I install it) there is a 2 legged rubber fitting that connects the bottom of the airbox to the two ram air tracks. The legs fit inside and are about 1/4 inch thick rubber.
I was thinking it would be probably benificial to make a carbon fiber track that fit over the ram inlets vice inside, freeing up more space and not slowing down the flow as the air compresses into the small rubber legs enroute to the airbox.
Damn if I were still in Hawaii, my buddy Steve would lay up a form for me. Those guys that build boats know how to form one off pieces fairly easy.....
What'ya think?
2014 BMW F800GSA
2013 Berg TE300
2007 KTM 525EXC
2006 Husqvarna SM610
2011 Beta 300 Trials/74 Suz RL250/71BSA250Trials
Old 05-09-2004, 10:49 AM
repoe3's Avatar
sounds good. hopefully the weather and schedule will hold out this week. looking forward to taking stinky winky, i mean rojo diablo out for a ride.
repoe3
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 05-09-2004, 03:38 PM
Firebolter - The early Mille air boot available from AF1 does exactly what you want to do. I made up a couple gaskets from rubber mat to seal between the frame openings & the boot horns as there is a slight gap there. Works great!
John B.
03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5
90 535im & 95 525i Touring
65, 66 Alfa Romeos
Old 05-09-2004, 04:31 PM
lennie's Avatar
I know from a test done by CBT and Mark Doebeck (ex Dyno Jet) that the RT fitted with the InDuct runs at 4 inches of water at 100 to 110mph. I am not sure, but it may have pegged the gauge.
The conversion puts this at .155 psi inside the airbox. This in itself to quote the owner, 'made a significant performance increase' with the addition of fuel via the Fuel Nanny.
On the dyno however, my development RT made small gains in various areas (as seen on my website) contrary to the on road gains.
As far as the difference to the S is concerned, I am still waiting for the tests to be done in the future.
Part of what makes the InDuct work is not just removing the restriction in the rear section, size of the mouth on, and the shape and cross sectional increase on the front section.
How much difference this makes is hard to substantiate with dyno numbers. It is interesting that some of you guys are still curious about the benefits.
Lennie
www.boxer-performance.com
1998 R1100S Yellow is the best (now departed from my life)
Old 05-09-2004, 07:07 PM
Firebolter's Avatar
bikpaintr, thanks for the tip! I'll check that out.
repoe, stinky winky? Man you can talk bad about my sister, even my girlfriend but when you start dissin my ride, thems fighting words boy!!!
2014 BMW F800GSA
2013 Berg TE300
2007 KTM 525EXC
Old 05-10-2004, 07:05 AM
