Effervescent's Avatar
How-to replace access. outlet fuse?
Got link?
Got pics?
Got advice?
Using my outlet to try and brew a cup of espresso turned out to be a stupid idea after all!
-Eff
"Moderator: Please change the subject of this thread from"I got my first speed ticket in U.S." to "I got my second and third speed ticket in U.S. at the same time""-martincito
Old 03-13-2006, 11:28 AM
"Instrument panel, horn, power socket...15 amps"
So I should double check that my horn and panel are out as well, correct?
New to 1100S fuses,
-Eff
Old 03-13-2006, 02:22 PM
Flatbutt1's Avatar
wish I could help ya bud, I got nuthin'
big blue tricycle
stare down the darkness and watch it fade
Old 03-13-2006, 04:57 PM
lol
Well, my panel lights and horn both work. Maybe there's a fuse in the 24inch BMW-to-cigarette adapter I was using.
Off to see if my vest warms up from the outlet.
-Eff
Old 03-13-2006, 05:20 PM
Living on borrowed time!
JonyRR's Avatar
OT
if you really want to run an espresso maker off your scoot, use 10 gauge wire off the batt with it's own 30 amp fuse or you wirin' harness will be like.....melted man, if the fuze didn't go
what's the amperage draw of that there koffeepot?.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 03-13-2006, 05:23 PM
It's a lil'guy. A travel one. Not like a big restuarant one. lol There's a sticker on the cord that read 6 amp. I mean, that should be a problem, right? (Ran it with the engine off.)
-Eff
Old 03-13-2006, 06:12 PM
unsafe at any speed
wswartzwel's Avatar
The outlet fuse is the same as the clock. If the clock still works then your problem is not the fuse. I have seen the plug/wires on the back of the acc. plug (the one mounted by the passenger peg) corrode in two... The tire throws road grime and rain on this connection... just something else you might check Eff.
Bill Swartzwelder
Old 03-13-2006, 06:18 PM
Going outside to check right now.
brb
-Eff
Old 03-13-2006, 06:34 PM
YIPPEE!!!
So, I have a 24 inch BMW-to-ciggie that runs from my outlet to my egg tankbag. Then I have a splitter that turns it into two ciggies (so I can run both a X50 and my GPS V) inside the egg. That splitter (cheapo from PepBoys) has a 5 amp fuse in it, which blew after about a minute of running the 6 amp espresso maker.
I think I am safe just going directly from the 24 inch adapter since the fuse seems to be a full 9 amp higher than the maker.
My eventual goal is to be able to have the Bob's rest locked, legs up on highway pegs, have a big open road ahead of me, loosen the Arai and raise it to the top of my head...say up in Maine along the coast or some sh_t and then flip the tankbag lid, wait 4 minutes, and sip away at espresso brewed on my 1100S at 70 mph.
Wait a minute, those cofee grinds are gonna get blown all over the place. Nevermind. I'm living a dream.
-Eff
PS Clock was working.
Old 03-13-2006, 07:01 PM
unsafe at any speed
wswartzwel's Avatar
Ding fries are done....
Bill Swartzwelder
Old 03-13-2006, 07:09 PM
You need a Nolan flip, duh!
aka Rev Z-Man -- RIP www.bmwforums.net
- 1950s Ford 9N Tractor
- 2021 Subaru Outback Onyx XT
- Drummer for 12 Days Straight
Old 03-13-2006, 08:46 PM
D-oh!
Well, I just went out and tried again. Wasn't enough juice, it appeared. The light on the converter was sorta pulsating not glowing steady.
I gave up after 3 minutes as it wasn't really getting hot.
Then I realized my ac/dc convertor is 70 watts and the device is 110-120 watts. The plot thickens.
-Eff
Old 03-13-2006, 09:01 PM
JonyRR's Avatar
hmmm...pulling a steady 6 amps outta that battery...make sure she's running
Old 03-13-2006, 09:39 PM
On that note, at what RPM is the charging system doing it's thing? 2,500RM?
It take 4 full minutes to make the espresso inside my house. I wouldn't want to idle the engine that long (cause of the heat production) but maybe a minute would take the edge off the battery drainage.
Then there's always the bump-start.
-Eff
Old 03-14-2006, 01:41 PM
be_are_why's Avatar
I'm going to keep an open mind and see where this is going.
But this thread has me absolutely bam-boozeled.
{_r1100s_} circa: 1999 / color: zwart
Old 03-14-2006, 01:53 PM
JonyRR's Avatar
one reason why BMW has an alternator with brushes is that it puts out more juice at a lower RPM than a permanent-magnet alternator (called 'break-even') where the charging system is supplying as much juice as the bike pulls out of the battery
breakeven on these is something around 2500 or so, as opposed to a typical japsikkle at roughly 4-5K RPM.
Still, pulling a steady 6 amp load over a period of time could tax those small gauge wires BMW loves so much; even the acc socvket has (what I consider) a small gauge. I've hacked and modded my OEM harness extensively and run heavier gauge wire on critical runs that handle a lot of amperage. My tankbag has a dedicated 10-gauge wire set (you MUST run a ground-side wire of the same gauge, at least, as the hot side) for the RD, GPS, and most importantly, gerbing suit and 'lectronic thermostat.
One thing I've found is that the BMW ground side starp for the batt needs to be yanked, the end cleaned that bolts to the engine, and that connection tightened guuud. It's your ground side and always ignored. Have an adaquate ground plane or be frustrated forever....
and low or fluctuating voltage can play hob with Mr. Motronic....
Old 03-14-2006, 02:39 PM
unsafe at any speed
wswartzwel's Avatar
Originally posted by Effervescent
D-oh!
-Eff
You are making things too difficult......
Bill Swartzwelder
Old 03-14-2006, 02:42 PM
JonyRR's Avatar
I got your AC-to-DC converter in a cube next to mine in Downtown Seattle. His name is Michelle and heshe's waiting to perform your 'conversion'
Old 03-14-2006, 02:45 PM
LOL
You guys are complete turkeys.
LOL
-Eff
Old 03-14-2006, 02:58 PM
wood-d's Avatar
On the 2004 'S' with wizzy brakes, they merged the two fuse boxes into one. Here is the fuse layout:
http://home.jtan.com/~wayne/R1100S%20Fuses.pdf
2004 R1100S (2zars)
1957 Matchless G11
Old 03-15-2006, 04:44 PM
