O2 sensor removal
Anyone know what size plug to use and where to get one? I want to remove mine for awhile. I just installed a San Jose Duct kit.
Thanks Lance |
unsafe at any speed
rumor has it that JonyRR is using a spark plug... something he learned in the 50's when doing flame throwing contests
http://splparts.com/Parts/Universal/Hardware/Fittings/default.asp has plugs to fill the hole... scroll down. $8
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 09-25-2006 at 06:25 PM.. |
Why not use the O2 sensor to plug the hole, it screws right in, no need to plug it in.
Leaving it in will just soot it up and kill it. Taking it out will be less of a restiction in the exhaust and I will gain 10 H.P. (G).
wswartzwel thanks for the info.
LT |
Living on borrowed time!
K&N makes a special bolt just for this...also the car accessories folks like holley or something. try a local car spped shop, and you do NOT want to leave the 02 sensor in but unplugged, as you will ruin it, as has been pointed out.
Bill, I run the K&N plug when the 02 sensor is out.
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
Is there anything to be gained by disconnecting the O2 sensor on a bike with standard air filter, but no catalytic converter?
See my bike blog on http://bikesindordogne.blogspot.com/ |
Banned
Might be a good thing to do. This is one person's tests about what happens to A/F ratio with the sensor removed. But there's newer information about the PC III on a thread in the BMWforums. http://tinyurl.com/6bvt23 Last edited by Boybiker3; 12-17-2008 at 10:46 AM.. |
my original tune setup worked great before I went to a PCIII (the pc is there baecause I intend to do MAJOR mods, like a 1200C crankshaft, 1136 cylinders, massive headwork and different cams)
try this setup: do a 0=0 TPS dialin as described in the lentini/dr. curve PDF (it's around here somewhere) yank the 02 sensor. yank the CCP (Cat code plug) NGK BKR7EA plugs (honda cycle part#) that setup is cheap, reverseable and I found it to make my scoot run mucho better. this is for an early model single spark machine. on a twinspark, I have no idea, as I don't own an OEM twinspark.
