Motorradfahrer
Eisernkreuz's Avatar
Send a message via AIM to Eisernkreuz
R1100S dyno results
A guy from BARF has a mobile dyno setup, so I put the ol' donkey on it.
Here is Chet running it on the dyno
And the results
I was told it's running very lean, as evidenced by the popping on closed throttle. I really don't have the money or drive to go and get a chip+tune for it, so I'm just going to make sure the air filter's clean, valves are properly set, and maybe throw in a set of iridium plugs.
-Miran
99 R1100SA
Old 07-31-2007, 09:35 AM
Isn't the power peak at 7500? It appears they ended the run at 7K - you probably have 3 or 4 more ponies to go. Which puts you at about 80 which is 5-10 less than most stock R1100S bikes, which means that if the dyno is reasonably accurate, you've got something slightly off-song, although not by a whole lot. Good looking torque curve.
- Mark
Old 07-31-2007, 10:23 AM
Actually you are only about 4 - 5 HP down. You should be getting around 80 - 82 at 7000 RPMs.
Old 07-31-2007, 02:39 PM
roger albert's Avatar
I'm with the Dr. on this one. Accurate dyno should show about 80hp at 7k and about 5 more at peak.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 07-31-2007, 03:01 PM
Send a message via AIM to ethan346 Send a message via Yahoo to ethan346
what should the dyno horsepower be on a dual spark R1100S? Any different than the single spark?
'04 R1100S
'06 VFR800 (RIP)
Old 07-31-2007, 05:35 PM
Motorradfahrer
From what I understand, the 2-spark doesn't really boost power that much as far as peak goes, but eliminates some of the dips and the surging.
-Miran
99 R1100SA
Old 07-31-2007, 06:27 PM
Motorradfahrer
Other bikes dyno'd that day were a stock GSXR1000 @ 155hp, Ducati 1098S w/ Termignoni pipes @ 143hp, and a couple SVs in the low 70s. It seemed pretty right on. I haven't checked my air filter in a while and I've been putting in a bunch of miles, maybe it's just a bit clogged up. I know my spark plugs are ok. I doubt they're a year old, but I've only had the bike for two months so I wouldn't know.
-Miran
99 R1100SA
Old 07-31-2007, 06:30 PM
