pwillikers's Avatar
11s right turn signal switch repairable?
The right handlebar combo switch (61317650744) is $180 from BMW - this to replace a broken $2 switch that is captive inside the combo switch. Have any of you ripped into this and replaced the switch? Advice? What switch did you use? Source etc?
Paul. '11 R1200RT, '09 Buell 1125cr, '08 Suzi SV650A, '00 Suzi SV650, '97 328i (with sticky ass tires - I love this car). And the bikes I used to own: '68 Bultaco 100, '69 Honda CL450, '71 Kawasaki Mach III, '71 OSSA Pioneer, '72 Honda MR175, '72 Benelli 250, '75 Yamaha RD350 (then college), '83 Honda VF750F (then kids),'96 MZ Skorpion, '99 R1100S, '01 SV650, '94 Honda VFR750F and '04 R1100S w/Öhlins an' stuff, most wrecked.
Old 10-22-2007, 08:50 AM
unsafe at any speed
wswartzwel's Avatar
I have disassembled, signal switches on many brands of bikes over the years.... usually they will snap apart, and a little emerycloth work has them going again.
Bill Swartzwelder
Old 10-22-2007, 09:02 AM
squall_line's Avatar
If not, you can pick one up on BBY for a LOT less than $180. If/when they get one, of course...
I presume that you've verified 100% that the switch is the fault point, and not any of the bulbs/sockets/relays? I had a non-functioning turn signal on a bike once, and it turned out that a bulb had vibrated loose in its socket.
J.J.
Mandarin / Black '99 R11S-A - black YoYo clamps, black wheels, black front forks.
Former bikes: '93 R100R, '93 K1100LT, '02 R1150RT, '03 K1200GT, '97 F650ST
Old 10-22-2007, 11:00 AM
pwillikers's Avatar
Yes, I've tested it to my satisfaction by tapping into the wires immediately adjacent. The switch never closes (electrically speaking of course).
Old 10-22-2007, 11:05 AM
Banned
The grip switches are pretty durable esp. the turns signals that are just "momentary-contact" switches. Not my first guess for the location of the problem. But they do have to take a lot of abuse and bad weather. I spray WD-40 into them regularly for the several benefits from spraying it. WD-40 and a bunch of pushes of the switch might fix your problem. I don't think WD-40 harms anything, so spray away.
Rebuilding a grip switch at home is tricky if you have to deal with little springs and other parts that fly across the room. But might be fun on a cold winter night.
A very happy day for me when I installed the Kissan Signal Minder. I was breaking my thumbs turning the signals on and esp. turning them off. Can't say much nice about certain of their business practices, but their Signal Minder works nicely. Stock set-up real PIA.
Old 10-22-2007, 12:00 PM
I've got the same problem. When I turn on the emergency flashers the both front and rear bulbs flash. I've been looking for a right switch assembly, but I have heated grips so I have to find one that is specified for heated grips.
I think I'll try taking it apart soon. Can't hurt (famous last words......).
Old 10-22-2007, 01:04 PM
Send a message via AIM to Bigred455
Paul, you can take them apart, I've done it. As far as finding replacement switches no idea.
-George Hill
'12 GSA, '00 Mandarin S, '09 HP2S, '99 Naked S, '03 Yam YZ250F, '91 Suz Dr350, '01 Yellow/Black S - Dead
Old 10-22-2007, 03:36 PM
Gone Bush
twodear's Avatar
I'll swap
I have a complete working switch set/brake master cylinder assembly on my track bike, a 1999 R1100S. I've removed all the things that the switch used to operate and have tied the wires back. The only purpose for the assembly now is to use the brake master cylinder and throttle assembly.
All of the wires and plugs are intact. If your front brake master cylinder and throttle assembly is in good working order and is compatible with what I have now, I'm willing to work a swap of some sort.
If enough is enough and more is better then too much should be just about right.
Member of AAAA (Association Against Acronym Abuse)
'22 H-D 'F' outfit, '46 Indian Chief outfit, a couple of early Honda Benlys, "BUBba" - R1150GS Adventure
Old 10-23-2007, 02:02 AM
pwillikers's Avatar
The Aussie to the rescue! Thanks.
Were I to separate the rear half of the right hand assembly that contains the switch components and send them to you, you'd send your working switch assy. to me? I'll post images when I get close to the .pdf to confirm that I know what we're talking about.
Old 10-23-2007, 08:48 AM
Be sure and let the rest of us know what's involved. I'd love to fix mine but would rather learn any hard lessons second hand....
Old 10-23-2007, 10:41 AM
I'm confused as to why one would need to replace the master cylinder reservoir with the switch assembly. They are independent of each other and can be removed and replaced as such.
J.J.
Old 10-23-2007, 12:03 PM
I hope they are talking about taking the actual turn signal switch apart and fixing that......
Old 10-23-2007, 12:11 PM
Nope. Sounds like Paul (pwillikers) is talking about trading switch assemblies and reservoirs with twodear. The switch assembly is all that needs to be traded, not any of the reservoirs or grips.
Of course, if the aussie doesn't have heated grips, Paul is a little out-of-luck.
I don't think anyone posting here so far has actually gotten to the point where they will be tearing into the assembly themselves yet. If I had a junk one to practice on, I'd gladly do it and take pictures and notations.
J.J.
Old 10-23-2007, 12:26 PM
pwillikers's Avatar
The first picture shows everything that is irrelevant to this discussion and stays on the bike.
This second picture shows the faulty part in question, the combo switch (#2 - containing the kill switch, the right turn signal switch and the turn signal cancel switch, NO heated grips switch) which can be separated from the master cylinder with the philips screw (#3) shown and one philips screw up from the bottom (#6 in the first picture). The wires attached to the switch go to a connector in the right relay box. After the two screws are removed and the wires disconnected, the combo switch is loose in your hands.
Old 10-23-2007, 12:44 PM
The right turn signal switch is what is bad (I think) on mine, at least it doesn't work. I was hoping someone would take one apart and "enlighten" the rest of us as to the proceedure and problems.....
I'm going to try the WD40 tonight just to make sure.
Old 10-23-2007, 12:48 PM
Gone Bush
twodear's Avatar
It is okay by me. And my bike doesn't have heated hand grips.
The pictures make it clear what you are talking about. I'll PM you with my home email address.
2D
Old 10-25-2007, 10:14 PM
pwillikers's Avatar
Fixed
Well, once again props to George and Billy who, of course, are correct. I pulled the switch off and pried the orange push button loose from it's pivots.
which allowed me to pull the switch out in my hand.
I pulled off the rubber boot and was able to get to the oxidized contacts inside.
A little emory cloth on the contacts, confirm operation with an ohm meter and some straight pins through the insulation, reassemble and back in business.
I be blinkin'!
Old 10-27-2007, 12:47 PM
Gone Bush
twodear's Avatar
I think that is terrific! Looking at the way the parts are designed, it seems made to be disassembled and fixed rather than a disposable subassembly that is "Not Servicable By Owner".
All the little bits must have been designed by a series of graduate engineers locked in a dungeon, working for a number of years to attain a promotion that gets them onto a floor with windows. Then some specialist company had to quote price and delivery for a bag full of little rubber boots, or brass contacts or cast black plastic. Then some other company quoted price and delivery to assemble the discrete bits into a working assembly that was delivered to and eventually bolted onto a handlebar at BMW.
With that degree of tiny detail and bespoke parts, it is no wonder that these relatively low production machines cost so much.
Old 10-27-2007, 06:44 PM
unsafe at any speed
wswartzwel's Avatar
Congrats on the courage to boldly go, where you have not been before Paul!
Great pics for others future use to BTW.
Bill Swartzwelder
Old 10-27-2007, 07:35 PM
pwillikers's Avatar
Thanks Billy. It wasn't a lack of courage it was an excess of stupidity that had me stymied. I have enough "courage" that I'm often able to get myself way in over my head in almost any endeavor. It's the smarts parts and brain farts.
Thanks as always for the generous offer of your accumulated knowledge. And, I'm disciplining myself to picture document these repair adventures for the benefit of those who follow.
Old 10-28-2007, 09:30 AM
