How do use I use Carbtune II
The wife has bought me a Carbtune II (yeap- you read it right). It looks very nice but need some advice how to use it ????
Has any of you folk got any advice or better still, instructions???
Cheers
PS I ride a r1200s
Old 05-01-2008, 10:38 AM
Band.
You need to find the vacuum port opening that the little 'adapters' will fit into. On my 4-cyl Honda, the vacuum ports are on the Head, not the carb, and there's a little phillips head screw that you remove and install the adapters that came with the carbtune. I'm pretty clueless as to where they would be on your bike.
Once you find that spot, though, you're almost all the way there. Hook a line from the carbtune up to each adapter you installed. Hang it up vertical, and start up the bike and let it idle. You need to find the fine adjustment that will adjust the butterflys on each carb. Fiddle around until the vacuum of each carb sucks the fluid up the carbtune tube to an equal amount for each carb. Good times!
Sorry, that's a pretty awful description, but I don't know much about your bike. Good luck!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 05-01-2008, 10:45 AM
Hi,
I've got as far as fitting pipes to vacuum but dont know where to look to adjust ??
Old 05-01-2008, 10:53 AM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
On the 12, you can look as much as you want to, you CAN NOT adjust it yourself... one of the perils of the newer motor... the old one was easy to do, brass screws and Bowden cables... a turn here and a turn there throughout different RPM's and you were done!
With the Hex-Heads... you make a trip to the dealer and hope for the best!
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 05-01-2008, 11:26 AM
Is that definate - I've plenty of hex head tools
Old 05-01-2008, 11:36 AM
signit98's Avatar
If you have the computer software to make the adjustments, you'll be fine...
Old 05-01-2008, 12:03 PM
Living on borrowed time!
JonyRR's Avatar
the R1200S uses an electronically controlled stepper motor for idle adjustment, not an idle air bypass as the R11 does.
You are SOL here. One more reason I don't like the hexhead series.
You have to hook up th the DEALER'S computer, get raped by the dealer and run a good chance of some shmuck who's computer illeterate screwing it up worse.
This may be PROGRESS, but it's dam sure NOT BETTER.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 05-01-2008, 12:11 PM
tm1100s's Avatar
Greenbank, I also have one of these Carbtune units, and aside from the obvious problems adjusting the R12S, I found it to be usable but a little inaccurate. If you have the same one I do, there is no liquid. The columns have a metal bar in a calibrated sized cylinder attached to what is probably a calibrated (somewhat) spring. The vacuum pulls the weight of the cylinder and spring.
I found that after attaching and adjusting the R1100S with this, I needed to swap connections and check that the results were the same for each cylinder on EACH side of the carbtune (usually not) and then adjust for differences. Otherwise it's a neat, clean easy to use tool.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 05-01-2008, 04:01 PM
DanceswPavement's Avatar
Send a message via AIM to DanceswPavement
What's better, Carbtune (now Pro) or Twinmax? I'm going to attempt my 24K service (with the aid of the wealth of info on this BB of course).
Asphalt is the canvas. Paint it with motion.
Old 05-02-2008, 07:29 AM
Looks like I have a carbtune pro II for sale!!!!
Old 05-02-2008, 07:45 AM
peter f's Avatar
Keep it for the record...he he (and/or for the bike after R12S).
Old 05-02-2008, 08:26 AM
Man, that sucks! I was planning to get the synch tool too and keeping it finely adjusted myself. Thanks for saving me the $$$. Why couldn't the computer monitor vacuum on both cylinders and adjust stepper motors automagically on the fly? Now that would be both progress and better...
Mike
'07 BMW R1200S
'99 Ducati 996
'09 Husky TE450
Old 05-02-2008, 11:26 AM
ExarKunONe's Avatar
Send a message via AIM to ExarKunONe Send a message via Skype™ to ExarKunONe
A note on the CarbTune: For our bikes you have to use it updside down for it to register (usually) and be accurate. I really like mine. Small and cheap!
01 BMW R1100s, 99 R6 for the racetrack.
Old 05-02-2008, 09:31 PM
sdaddy's Avatar
I know you might have been kidding..... but is there somewhere to buy the software so we can work on our own bikes - once I "move up" to the R1200S from my R1100S (which is for sale)?
Lotus 7 - 400bhp/tonne
R1200S - for sale
'74 Guzzi Eldorado & '79 SR 500
'09 Z51 Vette
'05 Lotus Elise
Old 05-03-2008, 07:06 AM
Banned
Even if there is software out there, you'll still need some trustworthy transducers, A/D converters, etc.
BTW, now that Greenbank has located any vacuum ports, he can install a crossover line.
Old 05-03-2008, 07:53 AM
