Head Bolt tightening?
How often do i need to tighten or retorque the head bolts? the Manual only says at 600 miles but should it be also done when performing the valve adjustment? Or maybe periodically other than that?
What if I do not know what the previous owner did for service and if it was done at all? Im at 16,000 miles. Will it hurt to just do it as a precaution?
Old 01-25-2009, 06:57 AM
the reason that manual only says to tighten at the 600 mile checkup is because that is the only time you retorque the head bolts- unless you take the heads entirely off, an uncommon event.
contact your local dealer, give him your VIN #, he should be able to tell you the service history conducted by any dealer in the US.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 01-25-2009, 07:17 AM
There are some folks who recommend doing it periodically, but the majority of bikes get it during the initial service and then never again. My bike is nearing 50K and no issues.
It's not a simple torque number - you're supposed to torque to an initial value and the turn the bolt a specified number of degrees which requires a special tool. Which means that if you want to re-do it, you should back things off and start over. This sounds like an opportunity to break something that isn't broken to me.
I'd only do it if I noted leaking.
- Mark
Old 01-25-2009, 10:11 AM
roger albert's Avatar
If you can't find any records, then doing it now won't hurt anything.
They don't need to be done often, as the old ones did, but I've definitely seen more high mileage headgasket failures in my shop on those that never get it done after the initial service. But these truly don't much need it. I tweak them at the 48k service, and about that often afterwards. Not often at all. Pretty close to set and forget.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 01-25-2009, 10:48 AM
No try, do or not do
shreddr's Avatar
What about the studs? when you pull the heads do you need to retorque the studs? There really are no head "bolts" they are nuts. And how do you torque the studs?
2017 R1200GSW Rallye Shreddr Signature Model
Old 01-25-2009, 02:57 PM
Thanks guys. Im pretty sure the PO did his service at the dealer so I will call them tommorow.
I will just adjust the valves up and be done then.
Old 01-25-2009, 07:33 PM
