JATO, he already needs a chute just to be legal. A musician and an artist to. You have done a very clean and professional job on that ride. Great lines, symmetry and far improved power. You da man. Wish you lived closer.
Shredder,
Those headers look fantastic. I want one. It seems to be an undated version of what they first brought out. The headers sweep together in front of the motor earlier and I really like the look of them. Cheers
Andrew Black R1200S |
It saves on the chicken stripe riding to the twisties.
![]() I'm .3 miles from the real deal where it's parked in a dark, climate/ humidity controlled basement. It sits next to a Harley "mare" to keep it calm. ![]() |
No try, do or not do
i think Nail just admitted to being a Fag......
2017 R1200GSW Rallye Shreddr Signature Model |
...elica rossa...
...shreddr ; as promised... ...a picture of the Dzus fasteners... ...I know ; my brackets looks different from yours, but I also got the stock Ilmberger mounting bracket, and I could use these fasteners on that one also... bracket & fastener from the inside ![]() and from the outside ![]() (so ; no fiddling around with a nut and bolt) ![]() ...pan & pipes... ![]() ![]() .
Have a nice day ! Ron. R1200S + R1200RT |
Ron, your exhaust has the Cat!
![]() I am going to put some kind of quick fasteners on mine as well
...elica rossa...
![]() ...nope ; it hasn't... ...yes, it looks like it has a cat ; but it's totally empty...
Have a nice day ! Ron. R1200S + R1200RT Last edited by RoLoo; 11-17-2009 at 10:19 PM.. |
Ron ... it looks good and bling already
![]() Hope you find a nice color setup for the spoiler (colgate design !?) and of course again a fine tunings trip to Goes ![]()
Jack R1200S HP2 Sport 03-03-'09 (#1012) ABS,edit;Full Akra+RapidBike 137,3 HP/132,4Nm R1200GS Adventure '07,WP-EDS(up-dated to EDSII) edit;laser headers+RapidBike All gone R1100S '01,BBP-chip,K&N,Lasers,no cat 100.2 HP,K100RS 16v '91,R80/7 '78,R60/5 '74 |
...elica rossa...
got it !!
one... ![]() two... ![]() three... ![]() four... ![]() and five... ![]() ...of course ; the pan will be (re)sprayed in silver and red... ![]() ...BTW ; I didn't use the original HP2 Sport brackets, which I posted before. I modified the stock Ilmberger bracket, in order to use the Dzus fasteners... ...gorgeous piece of carbon fibre !... ![]() .
...elica rossa...
before...
![]() ...and after ![]()
... Beeming in BC
RoLoo - you have a PM
![]() Stunning work with the HPE headers and new bellypan. I'm glad you were able to make contact with Nigel at Sandbar. Looking forward to seeing the finished product. Best regards, Ian
2020 Ducati V4 (beast) 2007 R1200S (still perfect) '91 Ducati 907ie (sold - down payment contribution) '79 Kawasaki KZ1300 (sold - what a monster ![]() |
Ron, what's the story with the pregnant midpipe. You say it doesn't have a cat, but mine doesn't either, and it doesn't look like yours. Is this the Euro stealth method of making a system look certified while being open? or did the previous owner perform a catalystectomy?
...elica rossa...
...'pregnant midpipe'... ![]() …I kinda like it this way ; it has a stamped ‘E-keur’ in it, so indeed it looks certified… ...I must admit though, the straight non-cat-pipe you have got, give the it a cleaner look… ![]() ...see ; with a 'E-keur'... ![]() …I had to attach those springs like this ; sadly the Laser pipe doesn’t come with those little hooks… …and I had to use the springs, because the HPE and Laser don’t mix very well together… …there is just a tiny bit too much play, to tighten the Laser properly by only using the exhaust clamp… ![]() ...that's also the reason why I had to use the centre mounting bracket... ...to give the whole system a bit more stability... .
Have a nice day ! Ron. R1200S + R1200RT Last edited by RoLoo; 11-17-2009 at 10:20 PM.. |
Do not take too seriously
Note that db says nothing about composition of exhaust gasses. However, in some countries like Germany, in order for the bike to pass the bi-annual inspection, it also has to pass emissions regulations. Other countries, like Holland don't have such inspection and only require the exhaust to make not anymore noise than the amount the vehicle was approved for (+2db for margin) and do not require a catalyst converter to be present, even if there was one from the factory. So, when you buy a road legal exhaust here, you can separately buy a drop-in catalytic converter, should the country you live in require that. The differences in regulations also provide a nice loophole as you can easily drop in the cat for your inspection and remove it afterwards for a little bit extra power without the law being any wiser. ![]()
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
...elica rossa...
...TM ; normally HPE has two systems, one, with a cat in the centre pipe like the one I have, and two, a non-cat version, and that one comes with a straight centre pipe, like the one shreddr has...
...somehow, I have the cat. centre pipe without a cat. in it...
Yes, but the non-cat versions are typically designated as 'race' and not road legal while the cat versions typically have a drop-in cat. Speaking in general, not HPE specific.
...elica rossa...
..so, one could say that I now have a race-legal road going system...
the next question is whether that bulge actually enhances power. FMF makes pipes for 4-cycle dirt bikes that incorporate a bulge, which they claim enhances HP and reduces dB.
![]() http://www.fmfracing.com/Mode/Category/44
2017 R1200GSW Rallye Shreddr Signature Model Last edited by shreddr; 11-15-2009 at 03:14 AM.. |
...elica rossa...
...BTW, Mr. shreddr, this is the modification to the Ilmberger front bracket in order to get those Dzus fasteners properly used...
![]() ...nothing more ; nothing less... .
Thread Tools | |
Rate This Thread | |
