2005 BCR Laser Db Killer Question. Is it still in...
...thats what she said.
Just Kidding. I cant tell for sure if my Laser exhaust on my Boxer Cup Replica Still has the Db killers in. Can someone who has removed theirs take a look at my pic. Thanks, id hate to destroy something if it should not be removed.
Ben
1993 Ducati 900SS
1998 Ducati 748 (3,000 miles)
1991 Ducati 851 Strada
1987 K100RS BMW
1977 Porsche 911s coupe
Old 02-23-2010, 02:00 PM
No try, do or not do
shreddr's Avatar
i cant tell, but it looks like they either aren't in, or they have been cut way down.
2017 R1200GSW Rallye Shreddr Signature Model
Old 02-23-2010, 05:37 PM
tm1100s's Avatar
They're still in there. You can tell by the little step just inside each opening and you can see they extend about 2 1/2 inches in with a smaller diameter. But the most tell-tale sign is there's no hole at the bottom of each tube where the spot weld would be drilled out.
To take them out use a 5/16 inch drill, find the spot weld, and drill it out. Then put some penetrating oil around the edge, not wd40, something good. Wait a while then stick a broom handle or dowel in there and work them side-to-side and up and down until they loosen and come out. Some come out easy, some don't. Mine didn't. By the time I got them out they were almost unrecognizable from the slide hammer treatment.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 02-23-2010, 06:51 PM
tm1100s's Avatar
tm
Old 02-23-2010, 07:01 PM
I see the spot welds now. Thanks a million
Ben
1993 Ducati 900SS
1987 K100RS BMW
Old 02-24-2010, 05:55 AM
turboflyer's Avatar
Could I assume with them out there will be an increase in flow and HP or just more sound?
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 02-24-2010, 04:51 PM
tm1100s's Avatar
Yes, more hp.
Stock HP x 2 pipes - 2 dbkillers = ??????
tm
Old 02-24-2010, 06:40 PM
Dark Side of the Force...
X-Triple's Avatar
Expect at least a 5 rwhp gain!
'04 R1100SA
'05 K1200S
'04 BCR
'07 K1200S
'07 R1200S
Old 02-25-2010, 11:55 AM
turboflyer's Avatar
Seriously 5HP by just taking those suckers out, humm any chance of really doing damage to the pipes? Is that a dyno RWHP or just seat of the pants guesstimate.
Old 02-25-2010, 03:39 PM
my guess is he's kidding
1993 Ducati 900SS
1987 K100RS BMW
Old 02-25-2010, 03:41 PM
shreddr's Avatar
he's kidding. if you want to gain 5 RWHP then replace the stock header with the cat free Laser unit.
Old 02-25-2010, 03:49 PM
turboflyer's Avatar
That was the first thing I did for sure. Just purchased a air fuel ratio data logger. As soon as I can get the O2 bung on I can dial it in more. I know, dyno but I like doing stuff myself and having something left over in my tool box. I already like the tone of the BCP w/o the cat so if it will not flow better I dont need more DBs. I can get those from the duck.
Old 02-25-2010, 07:34 PM
roadrash666's Avatar
I'm not worried about power I know it doesn't come that easy(good rule of thumb: each hp over stock=$100) how much more bark?
05 Boxer Cup Replika
06 ZX6R rev happy track whore
Old 02-27-2010, 02:50 PM
shreddr's Avatar
it's exponential, not linear..
Old 02-27-2010, 02:55 PM
i just pulled the db killers out of the mufflers on my 05 bcr and didn't notice a whole lot of difference in the sound. The bike did start easier and idled a whole lot better though, I have to say that alone made it worth the effort to get those bastards out. It was kind of a pain in the ass(I too had to resort to a slide hammer)we'll see how it runs when I ride later in the week. Temps are supposed to be in the mid 40s and I can't wait to get out
Old 03-01-2010, 03:21 PM
turboflyer's Avatar
Interesting, better start and idle. I bet when you take her out and crank it on she is going to talk to you a bit louder. I might do it. I am just fearful of messing up the cans. I have 15K worth of sticking them in there.
Old 03-01-2010, 05:24 PM
tm1100s's Avatar
The biggest improvement with the '05 Laser system is with the removal of the cat and insertion of the Laser Sport Collector (I think this is what they call it), or something similar to this. I was originally told that the db killers were a zero backpressure addition that changes the tone, not the flow. Changing the pipe, removing the dbk's and changing the chip made a very noticeable difference overall.
tm
Old 03-01-2010, 06:21 PM
cyotee01's Avatar
"worth the effort to get those bastards out. It was kind of a pain in the ass"
Yep. But agree... you lose the almost 'fluffy' sound at idle/low revs. I'd recommend it but be patient as it could take an hour or so of coaxing to get them out without damaging anything (suggest you remove the mufflers from the system and do it in the garage & not on he bike, as you could damage the rear bodywork)
Old 03-02-2010, 08:45 PM
Regnat populus
boxercup's Avatar
BMW Roundel Broom Handle
Greetings,
To Remove:
  • Drill out the 6pm spot weld completely
  • Insert broom handle and wiggle them out.
To reinstall use a small SS screw, lock washer and bolt.
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 03-03-2010, 10:11 AM
There is one more way. I did this....it takes a little more time. I used a die grinder and milled the spot weld from the inside so I would not have a hole. As described above will be easyer and a little hole at 6 oclock is no big deal. After all that I still was not happy and bought staintune.....I`m happy.
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi
Old 03-03-2010, 10:28 AM
