Exhaust Options
I just picked up a 2001 BMW R1100S to go along with my 2012 Ducati Monster 1100 EVO. Compared to my Ducati, the BMW sounds like a sewing machine. Are there aftermarket pipes that would help bring a little character to the sound? Do you have to buy a full system, or would slip-ons do the job?
MillerTime
MillerTime
Indiana
2015 Ducati Monster 1200S Stripe
Old 12-28-2012, 04:18 AM
I have a full Remus system on my 2001 "S" and it really wakes this bike up. I have owned three S's and this is the first one that feels like it runs correctly and I believe it is all the exhaust.
It is a bit loud, I can't ride it without earplugs but I have heard from by standers it isn't as loud as I think, sounds great when you are on the throttle for sure.
One other thing, it will never sound like a Ducati and don't even try to make it. Nothing sounds like a Duck except the real thing.
Mike
Old 12-28-2012, 05:21 AM
No try, do or not do
shreddr's Avatar
The Laser system sounds pretty nice. You can get a lot more sound just by ditching the cat and replacing it with a y pipe
2017 R1200GSW Rallye Shreddr Signature Model
Check your PM's
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 12-28-2012, 06:43 AM
tree hugger, eats meat
Paulaner's Avatar
IMHO, the Laser sounds like tin crap next to my Ztechnik Ti system!
I get many compliments on teh sounds it makes
Barely passed sound at Laguna Seca, 92.2 db at full chat coming out of T5.
I also have a 2Bros carbon slip on that is supposedly VERY loud, haven't tried that one....
Len Willis
R1100SA LIGHT
Old 12-28-2012, 09:37 PM
Have any of you put on a cat delete pipe like the one here on ebay? If so, does it require a special chip? I would think it would help with the sound and the weight.
BMW R 1100 s Catalytic Converter Cat Eliminator Decat Mid Pipe Exhaust CA11 | eBay
MillerTime
Indiana
Old 12-29-2012, 05:08 AM
lht lht is offline
Old subject, more noise, but basically no more horses. It will get rid of some weight.
The stock cans and convertor are pretty stout. You will notice backfiring once you change them out. I think the convertor muffles the backfires on the stock setup.
Then you will start messing with the TPS, throttle synch, Techlusion Box, air screws,but
the backfiring will remain. HA,HA
LT
Old 12-29-2012, 07:46 AM
lht lht is offline
The Two Brothers is louder than the Z Technik slip-ons.
LT
Old 12-29-2012, 07:48 AM
Paulaner's Avatar
I've never done the dyno, but mine will pull wheel VERY easily with the pipes on...... when I went backto stock pipes once (for a trackday), I was very dissapointed in the midrange performance. Could barely get the front off the ground. Now All better with the pipe back on!
So maybe no more grunt at the top, but a definite improvement in the middle, right where it's needed.
I've never mounted the 2bros, the Ztek midpipe won't match and I refuse to put the original cat back on.
Looking for a Laser y-pipe, but not too hard.... I love the Ztek.
ps. No chip or fiddling with stuff, just standard plugs,valve check and tb synch. No popping issues! I love my bike.
Len Willis
R1100SA LIGHT
Old 12-29-2012, 09:35 PM
Hi all,
Does anyone know what weight difference there is between stock and a aftermarket pipe set,
Remus, Ztech, Lazer, Staintune, maybe someone weighed when changing over, i tend to compare if i can when fitting stuff...
New ride, 04 11s, totally stock, but working on it...
Cheers Jeremy
Old 12-30-2012, 02:59 AM
My experience as well, great low end pull with the Remus
Old 12-30-2012, 05:03 AM
Will a cat delete pipe like this one on ebay work with the stock mufflers and without a special ECU chip? I would think it would help the sound and lessen the weight.
MillerTime
Indiana
Old 12-30-2012, 05:18 AM
full Laswer system. dropped about 15 lbs, most of it from the mid-pipe/cat converter going bye-bye.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 12-30-2012, 08:38 AM
not a brand I/we have seen before, but looks like it should work fine. should be no issues running stock chip with stock cans and this pipe.
Old 01-02-2013, 11:11 AM
I ran an open pipe/SJ filter/Lennies Induct for probably 4/5 years,it will have a spot at around 4250 as flat as a witches tit but you can jump across it no probs,but then a PC came out and it was happy days!!
Old 01-02-2013, 11:28 AM
Hi,
I always thought that Staintune was the best looking (very shiny stainless steel) for the R1100s, and if you leave out the removable baffles then it will give over 100 db when tested at tracks that are sensitive about noise (I think I scored 103 at 5000rpm at 0.5 metres distance at at Cadwell Park)
I put mine on at about 18k miles (~1999/2000?), and I'm now at 151k miles with only the Y pipe changed for free by Staintune when it cracked. (there may be posts about that)
I did get a chip made up for the Staintune on my bike (with lennies induct)
It's still going.
Adrian
Last edited by adrianw; 01-03-2013 at 08:48 AM.. Reason: found rpm settings from cadwell
Old 01-03-2013, 08:45 AM
fastfrank
Guest
Posts: n/a
Yep I have been very happy with my Staintune too.
114,000 miles and still sounds great.
Old 01-03-2013, 02:06 PM
I've got the Remus full system and I'm really happy with it. Of course, I bought the bike this way, so I have no idea what it sounds like stock, but it sounds mean now. The popping noises, while maybe not the healthiest things in teh world, sound awesome, and when I really open it up, it screams. Normal riding with light throttle, though, I don't find it to be too loud at all.
2002 R1100S Boxer Cup Prep
Remus full exhaust, Lenny's intake, boosterplug
Old 01-03-2013, 02:12 PM
I've never seen the point in replacing an over weight stock system with an over weight aftermarket were's the logic in that,look for a Ztech,quality piece of kit that weighs zilch up against the rest,as I recall 50% less than stock system.
Old 01-03-2013, 02:32 PM
Man it's flat out here!
R111S's Avatar
+1 Ztecnik!
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 01-03-2013, 05:26 PM
