Jim, my apologies. You're correct. There's a diff between ignition connector and stick coil. Compare the diagrams 12_1226 (dual spark) and 12_0769 (single spark). Wow! $76 for a spark plug connector!
Phil Y, Kapolei, HI 04 BCR (not quite stock), 06 Buell Blast (grandson's first bike), 77 R100S w/sidecar "There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago |
I see you
Any chance there's an insulator that's rubbed thru and is shorting intermittently? Not that I know what I'm talking about just thinking out loud.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
Senior Member
Thanks very much for this resource and diagram! Now I know where to look for an IPC (illustrated parts diagram!) for the bike. If the wire was not functioning correctly and shorting out, there should be some sign of it on the wire where it was arc'ing to the head or ground, and so far have not seen any of that but will keep looking closely. Thx, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Registered Agitator
I replaced my wires with these..Brand New Aftermarket Spark Plug Wires For All Single Spark R850/1100/1150 Bikes and run the iridium version of the autolite 3923's, the bike seems to run really well with this combo and it is cheaper than oem wires. Your plug wires can be breaking down without visible signs.
Joe, no affiliation but Max BMW is awesome for on-line ordering/delivery of OEM parts. I've ordered everything from them w/no hassle. Fast, friendly service if your local bike store doesn't stock parts you need.
Senior Member
Great info guys! Thanks much!
Just put the new plugs in the bike and on my "100 yard course" (the street by my house) the bike started on two, ran smoothly and no backfiring during several runs up and down the street, so am hoping that its taken care of. Still am thinking about picking up a set of the aftermarket wires and changing them out. The bike is coming up on being 20 years old and thats a long time for the OEM wiring. Thanks again! Joe
Stick-coils, #3 in the diagram, are only on the twin-spark models like Phil Y's. They are the coil which disconnects from the plug and the plug wire.
![]() On single-spark models like the OP, #2 in the diagram, it is an extension on the plug wire to reach into the plug and they are molded onto the wires. The coil is under the tank. ![]() If both plugs look the same then it is probable a HES issue, fuel pump/filter problem, or coil. If the plugs are different then it could be a bad plug, plug wire or injector.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S. * 2000 S, color-Salmon 108K+ -sold * '17 Africa Twin-totaled* '09 F650GS twin-sold * '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ. |
Sounds like HES. If it is original I would look there first
Hawk 2002 R1150RT 2001 R1100S |
Senior Member
Well, good news! Changed out the plugs and just put 30 miles on the bike. Ran good and solid the entire time and not a hiccup!
Thx, Joe
Great news! Reinforces the old wrenching adage: try the easiest/cheapest things first!
Senior Member
Also reinforces to carry a spare set of plugs with you! At $2 each, its well worth it!
secondary coils did not exist until the twin-spark heads, circa 2004 (maybe '03).
"Wow I'm an idiot, thanks bikerfish!" Harleys are like opinions, every a-hole's got one! 2001 R11S "lite", with a few mods. 2009 F800GS. has a better saddle. and other stuff. (sold) 2016 R12GSW 3Black. wow. |
