Phil Y's Avatar
Stumped-troubleshooting issue
Replaced my right head (don't ask--whole 'nother thread!) and bike was running fine. Just about 600 miles and time to retorque the head but right cylinder all of a sudden, started running ratty (based on unscientific but discernible hand-above-header temp difference). Bike runs fairly between 2.5-4K but there is no power or acceleration. Won't idle below 2k. Oh, also replaced the fuel pump gasket to repair a leak. Checked to insure no lines were kinked. They weren't. Here's what I've done so far w/no success:
1. Change plugs
2. Swap stick coils side-to-side
3. Retorque head and adjust valves (they were a bit off but not much)
4. Swap injectors side-to-side
Since it's only on the right side, believe HES is ruled out. Looking for suggestions as to what to check/change. Bad main coil? Any suggestions will be greatly appreciated!
Phil Y, Kapolei, HI
04 BCR (not quite stock), 06 Buell Blast (grandson's first bike), 77 R100S w/sidecar
"There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago
Old 04-22-2013, 04:17 PM
EZ-RIDER's Avatar
Try looking at the Ignition sensor part # 12117673277
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 04-22-2013, 04:52 PM
re-seat the throttle cable in the RH throttle body, my bet is you disturbed it when doing work.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 04-22-2013, 05:08 PM
Phil Y's Avatar
@Richard--you're a genius! Cable housing had pulled out of the adjuster/stop. Reseated it and it purrs like a kitten!! THANK YOU!!
Phil Y, Kapolei, HI
Old 04-22-2013, 05:45 PM
No genius, just a victim of the same error a few years back. Luckily I found it quick.
Glad I could help, after your recent trials and tribulations you needed a cheap quick fix.
Old 04-22-2013, 06:08 PM
Phil Y's Avatar
Thanks again! Appreciate your sharing your lessons learned from hard knocks. I hope I'm good for a while! Ride safe! Do you really have nine bikes to choose from?!
Phil Y, Kapolei, HI
Old 04-22-2013, 06:14 PM
Dark Side of the Force...
X-Triple's Avatar
Your are truly a Jedi Master.
'04 R1100SA
'05 K1200S
'04 BCR
'07 K1200S
'07 R1200S
Old 04-25-2013, 04:45 AM
