Left Window won't go down at all
1st Post!!
Anyway, over the past couple of weeks, the driver's side window has stopped going down at times, whether trying to use the switch, or when the door is opened. Tonight, it stopped working all togehter, stuck in the fully closed position...so now when opening, closing the door it runs against the convertible top. When I try to use the switch, I can hear a clicking coming from the door. So I've read some of the posts relating to window problems, and I've heard about the regulator and/or motor. Could this be the issue, or since it was a bit intermittent before, could it be a loose connection of some sort? And if so, do the instructions on taking the door panel for the 911SC (found one of the Pelican Technical Articles) apply for the Boxster? It's a 99 model, with door panel airbags. Any insight would definitely be appreciated... Cheers! --Jairo |
Welcome to the BBS,
Unfortuantely, it is usually not a loose connection. Your window regulator is most likely shot. step 1: DISCONNECT BATTERY Removing the door panel is nothing like a SC. In the long run, it is actually easier. If memory serves there are 4 screws and a few clips to undo to remove the panel. Screws are located: under the "airbag" logo under the plastic cover for the inner door handle under the small trim piece on the door pull handle one in the door pocket After those are removed, you will need to remove the light in the door and the power mirror controls Then gently pry on the bottom of the door panel, the clips should release and the panel should lift off - BE CAREFUL there are wires and cables connected to the panel, You need to disconnect them after the panel is free The airbag is held in my 4 M6 bolts - make sure the battery is disconnected. Do not, under ANY circumstances tamper with the airbag when the power is connected. Further, do not reconnect battery power with an airbag disconnected. After that, removing the window regulator is pretty straight forward. AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
That did it! Just replaced the window regulator and it's working again...
Thank you!! --Jairo |
