Still Have Questions
OK, it has been a long time since I have been on line here. Getting ready to deploy to the gulf again so still have time for some research. I have a few basic questions. I read recently that the boxster engine can not be rebuilt, is that true? Also the RMS problem, I understand that it is less prevalent in the 2002 and later cars but has it been fixed in the newer boxsters? Thanks for any help.
Old 09-23-2007, 03:14 PM
Hey, thanks for all of the responses, really appreciate the help!!!
Old 09-30-2007, 05:22 PM
Grant Lenahan's Avatar
Mostly; Not really
Originally Posted by navydave View Post
:I read recently that the boxster engine can not be rebuilt, is that true? Also the RMS problem, I understand that it is less prevalent in the 2002 and later cars but has it been fixed in the newer boxsters?
1. These motors cannot generally be rebuilt for 2 reasons:
a) lack of parts available
b) cannot be bored or honed due to very complicated deposition process to put silicon on the inside walls of the cylinders. But unless you have catastrophic failure, you will almost NEVER wear through the silicon anyway
2. RMS is generally not a big issue anyway. Messy, but generally harmless unless it leaks a LOT. Never cars are less prone to it, but there are still RMS failures on 9x7 series cars.
Grant
Old 10-01-2007, 05:05 PM
You might want to search the busier Boxster Forums:
http://986forum.com/forums/forumdisplay.php?s=&forumid=5
http://www.renntech.org/forums/index.php?showforum=24
http://www.ppbb.com/board/986board.htm
Old 10-01-2007, 08:03 PM
