Can't insert Ignition Key
'Have 1999 Boxster. 'Had difficulty removing ignition key. 'Finally removed it. Now I can't insert key.
'Common problem? Am I looking at needing to replace ignition switch, or am I not aware of simple solution?
Old 05-18-2011, 08:53 PM
Mark from SC
It is my understanding that it is a common problem that there is a piece in the switch that 'breaks' easily. Supposedly common. I had it where when I pulled the key out, the system still thought the key was in, and it left everything 'on' and 'dinging'. I believe they had to replace the switch (been a while, so can't remember). I do remember, though, that my mechanic said he had replaced a bunch of them with the same issue.
Now, if you can't get the key in, not sure how you get it to the mechanic!
Old 05-19-2011, 03:56 AM
Doug&Julie's Avatar
See if this helps...
Pelican Technical Article: Boxster Ignition Switch Replacement - 986 / 987
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 05-19-2011, 09:07 AM
