Can I replace the brake fluid without using the PST2 or Durametric?
I am planning on changing the brake fluid on my 05 Boxster with the PSM. I read the article in the book and was wondering if it is necessary to use those softwares. I do have the durametric and only used it once to remove the service sign. It wasn't user friendly and don't want to mess other things up. What can possibly go wrong if I don't use the software?
Old 01-17-2012, 06:46 AM
JFP in PA's Avatar
You do not need to activate any systems to bleed the brakes and clutch hydraulics. Use of a PST II/PIWIS/Durametric for activation is only required if you have gotten enough air into the system that it has entered the ABS/PSM pump and control network.
Accrochez-vous bien de vos r๊ves..........."
Old 01-17-2012, 11:44 AM
Thank You Guys
Old 01-17-2012, 04:26 PM
