Guest
Posts: n/a
Getting fault code P1397 on 2000 996 C4. Can't figure out how to get to sensor with out dropping engine. Is thereanother way to get to it ?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Not sure what kind of vehicle you have, but here is some general info on the M96 engine:
There are two camshaft position sensors, depending on which side of the engine you are replacing it on the procedure varies. On the right side, remove the A/C compressor, then you can access the sensor. For the left side sensor, you will have to remove the left side intake manifold runners. Once removed you can remove the sensor. - Nick |
