Guest
Posts: n/a
Hello. I did the upgrade in my 2004 Box 2.7,MT and successfully activated it via PIWIS. Thanks for perfect step-by-step guide.
But I have one question. Is the '04 gauge cluster different than those in older models ? User guide shows some advance settings in OBC like language, check functions, etc. But after activating OBC I can only switch between trip odometer, distance, temp and speed limit. __________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster On Board Computer (OBC) Upgrade and Turn Signal Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
I am not sure. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick |
Hi Nick,
Thanks for rising up my topic. I've made a deep digging and found that There are 3 types of clusters in 986 1) Gen 1 clusters (1997-2000, not interchangeable with later clusters) 2) Gen 2, non dot-matrix (2000-2004) 3) Gen 2, dot matrix (2003-2004) #'s 2 and 3 are interchangeable with each other, but not #1. If your car came with OBC enabled from the factory and is 2003 or later, you get dot-matrix. If OBC was not enabled from the factory, you get standard gen 2 LCD. Cheers, Tomasz |
