Will a faulty crank position sensor throw a code? Engine doesn't seem to be getting ignition, only fuel. Starter cranks, no movement on tach, no codes on durametric.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Engine Sensor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 02-12-2016, 06:05 AM
Nick at Pelican Parts's Avatar
If it fails during engine operation, usually. If it is a circuit issue, always.
- Nick
JFP in PA's Avatar
It is very common for the crank position sensor to fail on these cars without throwing a code. When that occurs, the engine will spin over but not fire as the DME does not see the engine turning and does not turn on the fuel or ignition, and does not throw a code in the process, simply because nothing looks wrong to the DME.
Accrochez-vous bien de vos rêves..........."
Old 02-12-2016, 06:12 AM
