Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mike (guest)
Guest
Posts: n/a
There is a drain plug on the back side of the engine just above the starter motor. This plug should be removed to drain the fluid in the engine block. Your directions are simply draining the radiator. The power stearing fan will need to be lowered. Good luck, Mike
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Coolant Change
Old 05-07-2013, 05:34 AM
Nick at Pelican Parts's Avatar
Thanks for the info.
- Nick
