Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Jim (guest)
Guest
Posts: n/a
Are all of the above steps required to drop the sub frame assembly the ~10mm for clearance when removing the transmission pan? I attempted to just loosen the main supporting bolts on the sub frame assembly but nothing was moving. I assume lots of the other steps you outline are holding things in place.
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-02-2014, 02:04 PM
Nick at Pelican Parts's Avatar
This tech article shows what is needed to remove the pan.
- Nick
