Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Gentech (guest)
Guest
Posts: n/a
I'm trying to help my Grandson with his 2003 Mini. He is 16 and had the car less than a year. I have replaced the alternator twice. He had the low oil pressure problem due to a quick lube mess up and now his P/S is messing up. Sometimes it will start working if the steering wheel is worked back and forth after starting and stopping the engine several times. I'm hesitant to replace the pump because I feel like if the pump is bad it would never work. Do you have any suggestions?
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-25-2014, 06:44 PM
Nick at Pelican Parts's Avatar
Check the fluid level, If it is full and properly bled, the pump may be faulty. You can test system pressure using a power steering pump gauge.
- Nick
PS pump
Mini covers the PS pump to 150,000, know defective part for some years
Old 09-26-2014, 04:13 PM
