Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Joe (guest)
Guest
Posts: n/a
HiI have a '03 Cooper S on which 1 of the PLASTIC "bulb holders" i.e,., the square, plastic connector into which the 2 prongs of the bulb are plugged has cracked. I was able to jury-rig a fix w/ glue and electrical tape that enabled the bulb to be plugged-in & remounted in its cavity. That lasted ~ 5 months. It's now disintegrating. Is it possible to replace ONLY that square plastic connector ? The attached foto, though poorly focused, shows the part to which I am referring. I believe I can use the existing 4 wires 2 each in and out. Thanks.
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-20-2014, 11:20 AM
Nick at Pelican Parts's Avatar
There may be a repair kit, but most times with the headlight wiring, the entire headlight has to be replaced. Give our parts specialists a call at 1-888-280-7799 and they can help figure out which part or repair kit you need.
- Nick
914 Geek
You may also be able to find just the connector at a wrecker's. With luck, you can pop the electric contacts out of the plug body, and then do the same with yours and just replace the plug body.
Of course, there's no guarantee that the new plug would hold up any better than the old one. (Or, as a friend told me, "You already have used parts!")
--DD
Old 10-20-2014, 01:27 PM
